| diyAudio Sponsor | ||
I am looking for a Gibson GA20 schematic. It has (3) 12ay7's, (2) 6V6's, and (1) 5y3 in it. Any help would be apprecited. I have looked on line but keep turning up GA20's with octal input and driver tubes in them. |
#2 |
#3 |
Thanks but they are incorrect. I need the schematic with the 9 pin tubes in the front end.
#4 |
#5 |
Here is a third choice :
www.schematicheaven.com has a document called Gibson Amplifier Master Service book, file name Gibson_msm.pdf with tons of Gibson schematics in it. For the GA20-T is shows 12AY7 inputs, ie nine pin tubes, so it may be what you want. The downside is that the schematic is not perfectly legible.
Robert McLean |
#6 |
The schematic that Alejo posted looks correct. The other schematics have either incorrect number of tubes or types of tubes. I even emailed Gibson and they sent me the schematic with the octal front end in it. The 1956 Gibson looks like it is mostly correct. Was this amplifier produced by Weatherford amplifiers for Gibson?
#7 |
Schematic of Gibson GA 20 as built.
I am only getting about 2 volts total output from this with a sine wave input. Any ideas? |
| su-g95 schematic needed. | oxydiode | Solid State | 13 | 6th December 2009 10:43 PM |
| Schematic needed. | sivan_and | Everything Else | 0 | 12th August 2009 08:34 AM |
| Schematic needed | Skoda_101 | Solid State | 0 | 15th May 2006 03:12 PM |
| schematic needed | milos_r | Solid State | 5 | 17th January 2005 11:46 AM |
| Needed schematic.... | di4kata | Tubes / Valves | 8 | 14th June 2004 07:21 AM |
| Page generated in 0.07612 seconds (77.42% PHP - 22.58% MySQL) with 11 queries |
