diyAudio Sponsor
Old 30th November 2006, 09:28 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default Rogers Cadet III Phono Stage
I just rescued this amp from a recycling centre. It's the integrated version with control unit & amplifier in 1 case (wooden - will post pics when I get a chance).
I don't know if it works yet but I wondered how its phono stage was rated in the grand scheme of things (the EL86 tubes were considered low noise & high gain I think). I need a phono preamp/amp & thought this would be a good place to start.
I am a solid state guy but always wanted to experiment with & hear a tube amp. So this is a perfect free intro (if I don't have to replace tubes - I know 40 yr old caps should be tested & probably replaced).
Before I spend any money on this is it worthwhile?
John
Old 1st December 2006, 04:52 PM   #2
kevinkr's Avatar
Should be a perfect amplifier to learn on.
Given the age of the amplifier expect to replace all of the electrolytics.
Someone here probably has the schematic as well.
I just found this very useful link to a cadet website. The manual includes the schematic:
http://www.btinternet.com/~a.d.richa...det/cadet.html
edit: add link to website
www.kta-hifi.net
Old 1st December 2006, 04:55 PM   #3
Banned
Got the schematic from the net thanks Kevin - just wondered if anybody had a view on the quality of the phono - I will probably reanimate an old thread on the Cadet to query existing owners of this amp.
John
Old 1st December 2006, 04:58 PM   #4
kevinkr's Avatar
Hi John,
It's a very basic design, but seems like a good point to start. Once you fix this neat little amp up you will have a better understanding of tube (valve) designs and might be ready to tackle a design of your own.
Just be sure to familiarize yourself with good safe practice which you can find right here in tubes.
Must have been posting simultaneously.
www.kta-hifi.net
Old 1st December 2006, 05:09 PM   #5
Banned
Thanks for the advice Kevin - will heed your warnings
John
Old 2nd December 2006, 08:36 AM   #6
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Hi.
I've had a couple of these little amps although I did not use the phono section as I am totally CD based.
They go loud enough for most people in the domestic environment ( using QUAD11 ) but do run out of power when pushed hard , as you would expect.
The sound quality is average and the ones I had tended to be a little noisy - hiss and hum.
Having said that, they have a great following. Well worth the effort getting it going again especially if the front panel is in good condition.
I sold mine at the Tunbridge Audiojumble - no problems.
Andy
Rogers Cadet III Schematics needlesview Tubes / Valves 23 14th September 2007 08:50 AM
Rogers Cadet III PU Adapter Jon Bradbury Tubes / Valves 16 19th January 2007 03:45 PM
Rogers Cadet III Power problem ? stephen_chrol Tubes / Valves 33 7th January 2007 10:04 PM
Rogers Cadet III - balance control Tandrews Tubes / Valves 16 19th June 2006 01:53 PM
rogers cadet mk3 hummm..... boxenergy Tubes / Valves 1 21st April 2005 11:30 PM
Page generated in 0.08475 seconds (75.83% PHP - 24.17% MySQL) with 10 queries
