diyAudio Sponsor
Old 30th November 2006, 01:23 AM   #1
dsavitsk's Avatar
Default Rectifier that drops lots of volts?
I am having trouble sourceing the power transformer I want. A 250-0-250 with a gz34 gives me about the voltage I want, but the only thing I can find is 300-0-300 (I am looking for a James to match the OPTs, and euphonia is out of stock and no one else (James/THL, and a few others) will answer my emails). So, I am looking for an octal rectifier tube that does not need more than a 5V/2A winding that can drop a few more volts. Any suggestions?
http://www.ecpaudio.com
Old 30th November 2006, 01:34 AM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
use LC filter
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 30th November 2006, 01:39 AM   #3
sorenj07's Avatar
Try a 5U4? This is PSUDII right? Is there no way you could sneak a little 3-amp filament transformer under the hood of the amp? I don't know any rectifiers that fit your criteria otherwise...
edit: or a LC filter. What is the desired voltage and current?
Old 30th November 2006, 02:01 AM   #4
kevinkr's Avatar
5R4...
www.kta-hifi.net
Old 30th November 2006, 02:07 AM   #5
I've been working with the GZ34 (5AR4), 5R4 and 5U4GB. I can get the VDC I need from the GZ34, and the others (both directly heated) give quite a bit less, due to a voltage drop that kicks in depending on the current drawn. Try a 5R4 with a 10H choke in LC, adding an input cap well *under* 4 muF. The 5U4GB may give you a little more output (but maybe not much when under load).
As an example, in one case I got 352 VDC under load with the GZ34, and 328 VDC with the 5R4. You can source all these from Jim McShane.
Old 30th November 2006, 04:51 AM   #6
Tweeker is offline Tweeker  United States
I have 240-0-240 (read: industrial control transformers) PTs coming out of my ears. Although, they arnt purty like the James.
Be sure your foil hat has a good low impedance ground.
Old 30th November 2006, 05:26 AM   #7
dsavitsk's Avatar
Yeah, this is really all about purtyness. here's the "breadboard" version of the amp
and that Hammond is just ruining it. I have a fancy padauk case made and am getting the top plate machined professionally, so it just seems wrong to not have a nice looking PT. Though, if I can't get the James I may just go for a custom EP, or even a 300 series Hammond.
Thanks for all the tube suggestions too. The PS is a RCRCLC followed by a regulator. I can increase the resistors a little, too.
Old 30th November 2006, 12:49 PM   #8
Wow, that's nice looking. Your OPTs are beautiful.
The 5R4 is a bigger tube than the GZ34, but is very handsome, even inside. My version has a brown base -- would base color matter to you for a rectifier tube?
Can't wait to see the final project.
--Jeff
Old 30th November 2006, 01:40 PM   #9
Sherman is offline Sherman  United States
A 5U4-G drops a lot of volts (forget how many) but needs a 5V, 3A secondary.
I haven't dealt with these guys but maybe they can help locate a James PTX.
http://www.tubeaudiokits.com/index.htm
--Sherman
Adcoms with lots of DC offset. Lots! ben62670 Solid State 71 16th February 2010 03:01 AM
12 volts drops to 6 when amp is powerd on DAKOS Car Audio 22 1st February 2009 02:19 PM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
Page generated in 0.09245 seconds (80.10% PHP - 19.90% MySQL) with 10 queries
