diyAudio Sponsor
Old 29th November 2006, 12:04 PM   #1
Question Matching capacitors
Hi all,
I need to match some capacitors for a RIAA network on a phono stage and since I don't have a way to measure them I am wondering if it can be done with a 555 IC and a frequency meter (my multimeter has a freq. meter up to 200 KHz).
With a 555 timer in astable oscillator, if I choose the resistors (1% or better) for a target frequency I think I could easily match the capacitors and get a very good match. What do you think?
Thanks im advance.
Luis
Old 29th November 2006, 12:38 PM   #2
SY's Avatar
The easy thing is that as long as you get the channel-to-channel match down to a fine point, the actual deviation from nominal is less important. So relative matching is more important than absolute matching, IMO.
If you've got a two channel scope, you can use a 1kHz square wave and match caps by putting them in an RC lowpass and measuring rise-time.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 29th November 2006, 01:24 PM   #3
Hi SY,
I understand that in the case of a RIAA network the matching between channels is more important than the absolute values of the caps.
I don't have a 'scope, that is why I was thinking of using a 555 and my multimeter as a frequency meter.
Luis
Old 29th November 2006, 11:55 PM   #4
Brian Beck's Avatar
I think you may have a good idea for a cap tester using the 555 with precision resistors and a counter. At least you can cull out caps which deviate far outside the center value, and you can match any two caps to each other pretty closely. The 555 spec sheet indicates that accuracy of the frequency of an astable oscillator will be about 2%, plus another few points over temperature. If you happened to have a known precision (1%) capacitor, you could "calibrate" the jig. For a few pennies, or Eurocents, you can easily give it a try. Let us know how well it works.
Brian
Old 30th November 2006, 12:22 AM   #5
Hi Brian,
Thank you for your kind reply. I'll order the capacitors in a few days and will post my results.
Luis
Old 30th November 2006, 10:49 PM   #6
One gets a Japanese RCL meter for the cost of a moderately expensive multimeter (at least here in the RSA). If electronics is your hobby, it might well pay you to get such an instrument. I find it very handy and use it often. I am amazed at the amount some caps can be out, often barely (or not) making 10%. Also, the same make and value might all be out but all almost equal (same batch?)
Do consider buying such an instrument.
Matching capacitors for filter redrabbit Parts 4 3rd July 2008 10:14 AM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Matching Capacitors Super_BQ Solid State 1 10th October 2001 02:42 AM
Page generated in 0.08133 seconds (73.19% PHP - 26.81% MySQL) with 10 queries
