| diyAudio Sponsor | ||
Sorry if this is a dumb question, but I am just getting into tubes... so here is my dumb question
I live in Europe, and have 220V 50Hz mains. Can I just rectify this and run it straight to the HV on my ECC82 tubes or do I really need a Transformer to feed the plates? I am going to run 2 tubes in a CE setup for a simple buffer to some inverted LM4780 and would love to not have to find a X-former for it. Will it blow a tube, will it brown out the city, do I need some inductance in there to feed the tubes? Can I just put in an inductor? I searched quite a bit, and I see a X-former in EVERY tube PS I have seen (At least the ones that run high voltage...) and they all seem to be expensive to buy. Thanks for any help. |
#2 |
Yes you do. For safety. Otherwise, you will kill yourself or start a fire. Possibly both. You need to go and do some reading around before doing anything to do with high voltages.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
Yes, but in my understanding of it, you could just find a 1:1 mains isolation transformer- fairly cheap and easy to come by.
james P.s. Please correct me if I am wrong- I have no experience of valve amps, just a limited knowledge of electronics. |
#4 |
DaMeat,
EC8010 is CORRECT. A direct connection to the AC mains is DEADLY DANGEROUS. Jrevillug's remark about an isolation trafo is spot on. The Triad N-68X has dual primaries, which make it suitable for use in both "120" V. and "240" zones. Bridge rectify for a "150" V. B+ rail. Use a "full wave" voltage doubler for a "300" V. B+ rail. At 50 VA, the N-68X can support a small power amp. It will be lightly stressed feeding a preamp. The Triad N-68X sells for about 11 USD. Figure on 10 Euros + VAT; hardly a "big ticket" item
Eli D. |
#5 | ||
#6 |
Hi DaMeat
One thing you can do is connect to trafo back to back. I attached a small drawing illustrating it. One extreme you connect to the mains, while the other side you connect to the PSU. The 12V you may use for the filaments, feeding it straight to the filaments or maybe rectifying and regulating it. www.dickbest.nl has some toroidal units 30VA for 8 euro's each. Go to the site, choose aanbiedingen en you can buy two pieces. I do not have connections with him, just buy some items now and then. Good luck Erik |
#7 |
OK, I understand the concerns for an isolation X-Former now. Worried about chassis GND suddenly being 220V, ground loops, and DC offset.
I think I could take care of all those problems in my design but not worth the trouble. I'll scrounge a couple "standard" X-Formers and wire them up like ErikdeBest suggests. BTW $10 is about all I'm spending so far on the whole amp, with sample chips and 2nd hand tubes so a "NEW" X-Former would be doubling my costs
#8 |
I tried going without a transformer once. I tripped a 20 Amp breaker. Then decided never to do that again!
#9 | |
Decided to resurect this thread as i have been wondering recently about dispensing with the power transformer to achieve an entirely transformerless amp. I was aware that most people said it was highly dangerous but I could not understand why or find answers that went beyond "ITS DANGEROUS" or saying things like:
I think 'why?' and then, 'can it be done safely?' However having two kids + cats + partner who is none to keen on high voltage stuff in the house anyway, I thought i should figure it out for sure either way. If this is such a dangerous idea there really should be a clear readily available explanation for anyone who is considering it. Maybe in the safety practices thread. (Although this is the last place I looked) Bearing in mind I'm in the UK - my thought process was as follows: If you start with the available rectifiers you either have half wave Voltage doubler or full wave bridge. With a half wave rectifier, assuming everything is connected the right way and no DC potential between neutral and earth (a big and dangerous assumption, I know) you end up with your earth, a common at earth potential and rectified 240V line, (340V if feeding a cap). Fine. However If the previous assumptions were wrong you could end up with: Earth, a rectified line at near earth potential with whatever DC offset there may be and a common at 240V (340V) below this. So why is this a problem? Well assuming your chassis is earthed and the circuit common isn't tied to ground anywhere within, the greatest danger is from the connection terminals (speaker / RCA etc). The common for these would then be several hundred volts away from earth. Even assuming no-one touches these it would nicely fry any other piece of equipment you connect.I thought maybe you could have a small circuit to test which wire is neutral and then route the mains the opposite way if connected wrong, but the only way I can think of doing this is to test for current flow from (supposed) neutral to earth, but any current flowing to earth will trip the earth leakage breaker in the main fuse box and this will happen if there is any DC offset anyway. It might be possible to make this work but I gave up at that point. With the voltage doubler you get 2 lines out symmetrically either side of neutral at +/- 340V, but with live and neautral the wrong way you get 2 lines that bounce up and down referenced to earth, the lower between 0V and -680V, the upper between 0 and +680V. Not very useful for all the above reasons and more. That leaves the bridge. With this you get 2 rails symmetrically again at +/- 120V(170V) but as the live and neutral are treated the same by the rectifier it doesn't matter if they are the wrong way around. Now +/- 170V might not sound very useful but as I said- this is for a transformerless amp, needing symmetrical +/- lines for the output stage. so this would be ideal. The only problem I can see is the DC offset which could still potentially fry other equipment, but this could be avoided in part by 2 equal resistors in series across the rectifier output and then tying the center point (theoretical 0V) to earth. Any offset would then trip the earth leak breaker and stop any damage occuring (...and the use of any electricity in the house ). There is probably a better way...I am still a bit of a newbie to audio electronics so PLEASE tell me If my thinking is way out, but to me this last solution seems reasonably safe. As I said I have kids / pets etc... so I am careful, thinking carefully before trying anything. Judging by some posts I have read others are not so cautious and prefer to tinker and experiment rather than think. So in my view people need to be given more info than "IT'S DANGEROUS!"
StoneT |
#10 |
Hi Stone T,
I thought Miles spelled it out pretty well in his response to the original poster. Mistakes happen in house wiring all the time, deleting the transformer removes all circuit isolation from these sorts of errors resulting in the possibility of circuit common getting connected to the hot side of the mains. You never want the possibility of exposure to mains voltage if possible. Obviously high voltage supplies in tube/valve amps are lethal in their own right, but usually if a device malfunctions and suffers a catastrophic failure high current mains voltage won't normally appear on the outputs or chassis which with a single unfortunate coincidence could occur quite easily without a transformer. (It's as much about odds as anything, and without a transformer they aren't in your favor.) Think of a transformer as your life insurance policy, with it few if any failures could be lethal to the end user, without it there is a distinct possibility that someone could be injured or killed if the ground connection you mention is absent on your receptacle or the hot and neutral are swapped. Both can happen, and I have found both instances in my own house - now all fixed. Transformers have another big benefit which is not often mentioned (and probably rightfully so) in these discussions and that is the transformer's leakage inductance provides a fair measure of protection to components on the secondary side from lightening generated and network switching transients. Note that regardless of what we all say about the advisability of this approach, your assurance (insurance in the US) company and local building inspector will take a dim view of this approach, particularly if you have an accident that results in injury or damage to property. I am sure there is online literature somewhere that spells out the hazards clearly from BSA, TUV, UL or CSA. I'd read it.. I'd do some research into the consequences of this design choice and I think you'll be able to persuade yourself quite effectively of the ill-advisability of this move.
www.kta-hifi.net |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 12:30 AM |
| ECC82 | BJK | Tubes / Valves | 6 | 24th April 2006 02:51 AM |
| KT88SE with ECC82 | sith | Tubes / Valves | 16 | 5th January 2004 01:24 AM |
| ECC82 with GC | sith | Chip Amps | 0 | 20th November 2003 06:01 PM |
| Page generated in 0.13311 seconds (85.48% PHP - 14.52% MySQL) with 11 queries |
