| diyAudio Sponsor | ||
Anyone know where I can find an output transformer for an Audio Innovations series 800 mk III amplifier?
Thanks, Jason Walker 519 818-6263 |
#2 |
Are you sure it's the transformer? Those units are thermally overtaxed,and the power resistors in the associated circuit always burn out. It's been along time since I've played with one, so I could be wrong.
I suspect it originally came through Glen, when it ws new, at Audio Two. And daumier marketing, the original importers (IIRC) are long gone. It could have been Mitch Kowasaki too. Or Evil Solution (Evolution). Ahhh..I forget all the main importers from years gone by.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#3 |
yup, its the output power transformer. i have it in for repair. Do you know where I can find one?
#4 |
hey chryslerjay. i did't know that you could get AudioInnovations gear in canada...
AI used very good quality mains and output transformers. You probably have the original output transformer specs. You could ask Lundahl (Sweden) if they could wind you a new one. Problem there is that even though it might match spec, it may still sound a little different. Then again maybe it would be ok. that's the chance you will have to take. You could get them to wind you two, but that will cost more $$$. Also, try boarder patrol in the U.K. to see if they can find you one... You could also try to find out if AI used this tranny in other equipment, prowl ebay for a few months and maybe get lucky... Rewinding is serious business. I wouldn't use the wire you got off it in any case. The insulation would be cracked from removal, and that could cause a nasty short . B+ Bcareful...
| Schematic: Audio Innovations, The first audio amplifier | maartentje | Tubes / Valves | 22 | 25th February 2010 06:34 AM |
| Audio Innovations 800 mk1 | ChrisW | Tubes / Valves | 0 | 6th July 2004 09:03 PM |
| Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First | Vortex | Tubes / Valves | 1 | 2nd February 2004 12:31 AM |
| WTB output transformers + scematics for Audio Innovations triode amp | webercarbmann | Swap Meet | 1 | 18th February 2002 09:18 PM |
| audio innovations 200 | rmgvs | Tubes / Valves | 2 | 11th June 2001 08:51 AM |
| Page generated in 0.08735 seconds (77.11% PHP - 22.89% MySQL) with 10 queries |
