As a christmas gift I got ECL86 and output tranny from vintage radio + ECC85. I know I can have some 2watt mono amp based on ecl86 but have no experience in tube amps. Tubes are in a very good condition.
Maybe someone of You have some simple&good scheme for SE using this tube???
Any hints?
Any hints?
Hi!
http://www.bonavolta.ch/hobby/en/audio/ecl86.htm
http://www.jogis-roehrenbude.de/
http://web.tiscali.it/audiofanatic3/Tipo/Valvole/pic_finali_SE/ECL86SE.jpg
You can also look for schematics that uses ECL82, that is pretty much the same tube (I THINK!!)
ECL86
Well...not really.
The ECL86/6GW8 is a triode+penthode containing 1/2 of the ECC83/12AX7A + an EL84/6BQ5.
Knowing that,it would be more interesting to look for circuits using exactly those tubes.
So the ECC83 can be used as an input amplifying stage and the EL84 as output tube.
Obviuosly it can be used in SE or PP circuits.
Well...not really.
okay. so far I have found few solutions on the web, but the most appealing to me is the one below - any comments, hints?
fdegrove - Thanks for links!
At the moment I'm going to stick to SE topology. The goal is not much power so why not))
scheme from the site:
http://borngraeber.hans.bei.t-online.de/default.htm
ECL86
Well,I can give you links to have a dozen more....
This circuit looks like something the guy did for his own fun,adding the EM80,a 10K volume pot,too many adjustable working points to my taste.
At least there is a usable link for the OPT and if it suits your needs as well,why not after all.
- Tubes / Valves
- ecl86&ecc85 scheme
