| diyAudio Sponsor | ||
I was just looking at the Edcor site and began wondering if any of their interstage matching transformers could be used as phase splitters.
Has anyone tried this with the Edcors? Which one(s) would you recommend? I'm about to place an order for some of their OPTs for a couple of projects and might add a pair of interstages to the order.
--Sherman |
#2 |
Sherman,
I've used the XSM10K/10K, and the XSM600/10K (as an input phase splitter) for years. They work great, and given their price, are a great deal. Just beware that Edcor is a bit optimistic about DC current through the primary. I use them in a parallel feed set up. But all my Edcors are at least five years old and new ones could be better at DC. Matt |
#3 |
I bought some about 6 months ago and they are an improvement and well worth the money.
#4 |
Thanks Matt & Burnedfingers!
Looks like I should add some interstage transformers to my order! I was originally planning on getting a pair of SE transformers for a small EL84 amp I have. That has turned into a pair of SE OPTs, a pair of P-P OPTs and now a pair or two of interstage trafos. Now all I have to do is find time to build something with all this!
--Sherman |
#5 |
I'm considering using something like the
http://edcorusa.com/products/transfo...sm15k-600.html to split phase and try and drive a pair of ultra-linear connected 6V6/6F6's a bit into A2. Would this be feasible with the larger 6EM7 triode on the other end unbalanced? I'd probably DC couple the smaller one in front for some decent gain. Or would parafeed be advisable? |
| Is this a phase splitter? | tom-vdl | Solid State | 9 | 15th October 2009 08:21 PM |
| Phase flip needed -Interstage Transformer? | jjman | Tubes / Valves | 20 | 20th January 2009 01:49 PM |
| phase splitter with Tr ? | sam8888ysl | Tubes / Valves | 9 | 22nd October 2008 11:28 AM |
| Phase Splitter Name | Gold_xyz | Tubes / Valves | 17 | 21st February 2008 09:48 AM |
| interstage convert to phase splitter | skyraider | Tubes / Valves | 8 | 21st September 2005 01:16 PM |
| Page generated in 0.08692 seconds (69.32% PHP - 30.68% MySQL) with 10 queries |
