811a Class A2
811a Class A2
Old 26th December 2002, 02:43 PM   #11
halojoy is offline halojoy  Sweden
On Hiatus
Arrow 15W Single End 6550C
from same site
All KITS at Elektro Akustik
/halo
Old 26th December 2002, 05:44 PM   #12
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
I've seen A2 designs based on the 811 before.
generally a stage or two of gain, and then a hefty tube, CF directly to the grid of the 811
I'll try and see what i can find
Old 5th March 2003, 05:27 PM   #13
jim is offline jim  Belgium
Default First try
Hi all,
This is going to be the (first) tryout for my 811A-class A2 amp.
Any comments are very welcome !!!!
Greetings
Jim
Old 5th March 2003, 06:02 PM   #14
Joel is offline Joel  United States
Joel's Avatar
I think you're going to have a problem with a 33k resistor in the cathode of an EL84, no?
Old 5th March 2003, 06:24 PM   #15
Joel
Why so ?
The EL84 anodecurrent flows into the grid of the 811A.
Jim
Old 5th March 2003, 06:49 PM   #16
Joel's Avatar
How much do you calculate is going through the 33k?
Also, where is the 280k grid resistor connected to?
Old 5th March 2003, 08:37 PM   #17
Joel,
The current through the 33k resistor is approx. 1 mA.
The 280k resistor goes to the bias supply (adjustable between
5-30V)
Jim
Old 5th March 2003, 10:18 PM   #18
bournville is offline bournville  United Kingdom
I think that the problem is probably a mistake on the circuit diagram - it shows Ig at 20-26ma, which implies a voltage of over 660 volts on the grid of the 811A, obviously impossible! With a current of only 1ma passing through the 33k resistor that would give a voltage of 33 on the 811A grid, a much more reasonable figure.
Old 6th March 2003, 11:12 AM   #19
Default Class A2 !!
Hi all,
The 20-26mA flows into the grid of the 811A,
just as the arrow indicates.
The anodecurrent of the EL84 splits into 20mA for
the 811A and approx. 1mA for the 33k resistor.
Jim
Old 6th March 2003, 11:20 AM   #20
Brett is offline Brett
Brett's Avatar
Default Re: Class A2 !!
Originally posted by jim
Hi all,
Jim
When you've got it running, try a CCS as the CF load. I think it's perfect for this application, and will likely result in lower distortion and more stable bias under dynamic conditions. One of Gary Pimm's BBMCCS would be what I'd try.
{added later} Or (read Kimmel's article below, and) run the EL84 as a pentode CF.
http://laplaza.taos.nm.us/~fvuotto/mustage.html
Just a thought.
I'm interested to see how this comes out. The Russian 811A's are reputedly at least as good as the NOS US ones, and are very cheap.
811a Class A2Hide this!Advertise here!
811a Opt GK Tubes / Valves 20 19th May 2008 01:08 PM
811A amp Class A2 MartinV56 Tubes / Valves 9 19th October 2007 04:34 PM
811 vs 811A? Ryssen Tubes / Valves 6 12th March 2007 10:11 PM
PP Amp using 811A rwellerson Tubes / Valves 13 1st February 2007 11:55 PM
Schematic needed 811a Class A2 mario2005 Tubes / Valves 8 7th May 2006 04:01 PM
