811a Class A2
811a Class A2
Old 28th July 2013, 08:29 AM   #101
H.Michi is offline H.Michi  Japan
Hello Tcqanh San,
Thank you for your comment.
Z out of 4P1L: 1/GM=200ohm
Z in of 811A: is supposedly around 2~3 K ohm, depending on input voltage.
Hiro
Old 28th July 2013, 09:59 AM   #102
tcqanh is offline tcqanh
Originally Posted by H.Michi View Post
Hello Tcqanh San,
Hiro
I remember that Zin = resistance of G1 in operation point. Is it right ? Can I take Ohms' law in this case for calculation?
Old 28th July 2013, 05:35 PM   #103
JLH is offline JLH  United States
JLH's Avatar
No. The worse case grid impedance happens when the grid is driven to its most positive voltage. At that point you can use Ohm's Law to see what the worse case is.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 29th July 2013, 04:18 AM   #104
I'm saying 811A in this case with Vg1= 17.5V, Ig1 = 12mA. So, Rg1 ~ input impedance = 1458 ohms. Any wrong ?
Old 29th July 2013, 04:28 AM   #105
Hello Tcqanh San,
Hiro
Hi Michi,
There are many ways to keep down Zout of driver stage, especially with high Gm tube. Why do you choice 4P1L ? Because it make more complicated on filament circuit.
If you can, pls use 6BX7/6BL7 or EL34/6L6 in driver stage (these can run higher voltage much more than 4P1L). I'm waiting for your experiment . You can get one amplification stage with high mu, so your design become more simple.
Old 29th July 2013, 05:44 AM   #106
I think the resistance of vacuum tube does not apply ohm`s low.
I made following experiment with my 811A amp:
1. Connected 10 ohm resister in between Cathode of 4P1L and grid of 811A
2. Measured ac voltage across the resister at 18W output. That was 0.142V ac.
3. Ac current should be 0.142/10=0.0142A
4. Z=V/I 43.2V/0.0142A=3042 ohm
5. Measured ac voltages across the resister at 1W output. That was 0.033Vac.
6. Same calculation: Z=V/I 10.25V/0.0033A=3106 ohm
Frankly I am not sure above measurement is right one or not.
Hiro
Old 29th July 2013, 09:59 AM   #107
JLH's Avatar
That is wrong. For example, if the most positive the grid is driven is +40V and the grid current at +40V is 50mA, then the worse case is the grid impedance is 800 ohms. You should design your driver stage to handle the worse case. If you only design for the idle condition your driver will not be up to the task of driving the tube to full power.
811a Class A2Hide this!Advertise here!
811a Opt GK Tubes / Valves 20 19th May 2008 01:08 PM
811A amp Class A2 MartinV56 Tubes / Valves 9 19th October 2007 04:34 PM
811 vs 811A? Ryssen Tubes / Valves 6 12th March 2007 10:11 PM
PP Amp using 811A rwellerson Tubes / Valves 13 1st February 2007 11:55 PM
Schematic needed 811a Class A2 mario2005 Tubes / Valves 8 7th May 2006 04:01 PM
