| diyAudio Sponsor | ||
Before I go snapping up cheap TV dampers for use as rectifiers, got one question: What does it mean on the specs when the following is written...
Ehk +100V -900V The 900V is encouraging, but the 100V is of concern. I want to be sure these tubes can handle high enough voltages in typical tube amp service. Thanks for any help. |
#3 |
Hi Sy,
Forgive my stupidity, but which one is the max potential difference, ie. what's the significance of the + and - voltages? |
#4 |
Let's look it up...(searching for tube manual)... hmmm... maybe this big red book... Ehk : "voltage of heater with respect to cathode" - so the heater can be 100V positive or 900V negative with respect to cathode - or the cathode can be 900V POSITIVE with respect to heater.
But if you have a separate heater winding for rectifiers, use it. |
#5 |
On the topic of damper diodes, anyone have experience with these?
http://frank.pocnet.net/sheets/137/6/6BL4.pdf I picked up a few in Antique Electronic Supply's last sale. In the current sale still under $3 a pop. |
#6 |
6BL4 is a bit hungry - 3 amps. 6DM4, 6DT4 have the same performance at 1.2A
| damper diodes .... | sunrise | Tubes / Valves | 2 | 5th November 2008 10:05 PM |
| TV Damper Diodes | Jack Thomas | Tubes / Valves | 8 | 10th September 2007 04:23 PM |
| tv damper diodes | jarthel | Tubes / Valves | 1 | 19th April 2007 03:41 AM |
| Damper Diodes | hacknet | Tubes / Valves | 5 | 5th May 2004 08:35 AM |
| Page generated in 0.07663 seconds (70.86% PHP - 29.14% MySQL) with 10 queries |
