| diyAudio Sponsor | ||
#31 |
say what you think. Some of us talk through a hole in our hats.
regards Andrew T. |
#32 |
Cal Weldon said in part...
"Hail to the woodworkers. The true craftspeople of DIY" I took up wood working after I retired about 10 years ago, and it is a never ending learning process for me. Wood work is a completely different discipline from Tube Electronics or sheet metal crafting that I like to dabble in. |
#33 | |
My Dad was the head tech for several companies back in the 60's, one of which was Magnavox. Interestingly, besides electronics his passion was flying. That being said, I spent several years in the 60's in our 3 car garage holding up the end of his This N that (can use real terminology here) While he built a full size Pete Bowers Flybaby. (all wood single seat open cockpit) I got my first start in woodworking back then. In my teens I started in a Display Shop/Hardboard Fabricator, Did that 15 years, And spent 20 more in custom cabinetry and millwork. I spend way more time on electronics projects these day rather than woodworking. Oh, back to the topic of tolex. I know a lot of guys have their favorite adhesives, But, I have really gotten fond of Formica Brand #160 water based contact. No Fumes, Put it on with a foam roller, wait about 30 minutes and lay it up. I really like it on Tweed fabric also. Its fairly thin so its must be applied heavily, But, I can honestly say, You can use it indoors without seeing Elvis by the time your done. 99% odorless and soap and water Clean Up. Did this one last week. Trout |
#34 |
I agree on using some of the newer glues instead of the smelly contact cements. I used two fans in push-pull to ventilate my work area. I use a product from a company called "Custom Pak Adhesives". It's original purpose was/is to cement formica to counter tops and other construction jobs. It sounds about the same, the big improvement is no fumes and soap and water clean up. Additionaly if you mis-align a piece it is very easy to remove and reposition. This stuff works great with Tweed too. Your Tweed cabinet looks really nice, you did a really good job. What kind of amp is it? |
#35 | ||
haha,, a 5E3 of course!! Quote:
White? Milky? Somewhat Thin? Drys clear to whiteish in thicker spots? Weldwood also sells the stuff, But our local Lowes was always out. I buy the Formica Brand in gallon cans, Its much cheaper that way. Our Lowes generally has the Formica Brand #160 in stock in Qts and Gals, I live close enough that shipping in Custom Pak was not sensible. (Could not locate it locally) Trout Edit, BTW, That water based stuff has another nice feature, If you get a stubborn area that wants to lift, Simply get out Momma's old iron and a thick towel. It will improve adherence. Almost like doing veneer repair with white glue, Just less heat required. Even the heat from your hands will activate it. I have found if needed the heat on tweed works very easy, The Tweed is not very temp sensitive, But on tolex, Do not over-do it, Tolex will melt if overheated. |
#36 |
"It would not surprise me one bit if the Custom pack stuff and Formica stuff were one in the same."
The guy at Custom Pak told me that they repackage their product for other companies. So it wouldn't surprise me either if it was the same product. I will probably check out Lowes next time I need some. Otherwise I get mine directly from Custom Pak in a 1 gallon Jug (like Milk) and have to pay the postage. The 5E3 was my very first tube amp build almost 10 years ago, and my first dealing with Tweed covering. Lining up the pattern was a real challange. I added a TMB tone stack to my 5E3 to give it more versatility and it works really well. |
| Burnt my finger - OPA4134 | Ridin '24'z | Chip Amps | 8 | 11th April 2008 11:11 PM |
| FE127E hole size, Butt joints and using PVA glue with MDF | bluegti | Full Range | 32 | 19th June 2006 12:53 PM |
| Joints for enclosures | CrisTUFR | Multi-Way | 14 | 4th June 2004 08:29 PM |
| Finger Cellular Phone | Netlist | Digital Source | 8 | 14th November 2003 09:01 PM |
| Glue or Screw? | gchrist | Multi-Way | 40 | 19th July 2003 09:17 AM |
| Page generated in 0.10696 seconds (77.42% PHP - 22.58% MySQL) with 10 queries |
