Dear Mr. Alessandro,
I haven't Quad II - Forty scheme. This scheme is the same Quad II mono amplifier (KT66) 1949-1970. I have followed and checked the voltages in this scheme and montage. I have to tell you that Quad II - Forty has higher anode voltage than Quad II mono amp anode voltage.
Regards, Georgi Georgiev, Bulgaria
Please tell me that amplifier didn't cost very much money.
I've got the original quad II schematic here:
http://quadesl.com/refurb/refurb_quadTube.html
Sheldon
Sheldon
rossdt said:Thank you very much!
What is the black component under the rectifier?
Alessandro
It is a very low value thermister in series with the rectifier (5U4) filament to give a kind of slow power-up.
The Quad II-40 circuit is essentially the same as the Quad II, with some slightly different value resistors to accomodate the 6SH7 drivers. The other difference is the separate cathode resistors (bypassed) for the KT88 power tubes.
- Tubes / Valves
- Quad II - Forty
