| diyAudio Sponsor | ||
I think it unlikely, but does anyone have a schematic for this amp, ('cause it looks sweet)?
http://www.drzamps.com/route66.html Specifications: Power Output: 32 Watts Output Tubes: 2 - KT66 Preamp Tubes: 1 - EF86, 1-12AX7 Rectifier: 1 - GZ34 Controls: Volume, Treble, Bass Configurations: Head Colors: Black. Other custom wood finishes are available Dimensions: 17 1/2" W, 9 7/8" H, 9 1/2" D Weight: 22 lbs. General Info: "The Route 66 is an all original Dr.Z design based on the incredible KT-66 tube originally built by Genelex. This tube generates the "Milkshake Thick" tones, as heard on John Mayalls "Bluesbreaker" album featuring Eric Clapton (the "Beano Album" as it is known to many). This is not a duplicate of the Marshall JTM-45, but completely original spin with new tonal end results. The "Route 66" has a EF-86 front-end. For those not familiar with this tube, it is a 9 pin pentode , offering incredible gain and input dynamics. It is normally used in high-end stereos, most often for its accurate transfer of input signal, balance, and headroom. The amp features a deceptively simple tone stack, consisting of Volume, Bass, and Treble, which feeds a non-negative feedback Phase Inverter, for true harmonic content and full output tube dynamics. It has a GZ-34 Tube Rectifier to complete the round enveloped tone. The amp has piano-like clarity with endless sustain, even at low volumes. Its 32 watts truly sing when driven hard in a focused, thick distortion, with the tightest bass response you've ever heard." |
#2 |
Splendid marking puff.
As for a diagram, I'd say it's probably a Mullard 5-20 circuit but with KT66 instead of EL34. Standard stuff.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
I'll look into that..
Thanks! |
#4 |
Actually I don't think it is exactly like the Mullard 5-20, first of all having designed a few guitar amplifiers for a living I believe that the tone stack is interposed between the EF86 and the 12AX7, secondly it is clearly mentioned that the amplifier does not use feedback back to the phase inverter.
I would try running the EF86 in current starved mode for the most gain possible. In this application the volume pot on the guitar is probably going to determine whether or not you overdrive the EF86 and by how much. Place the master volume (1M ohm pot) after the tone stack. The master volume will determine by how much you overdrive the power amp when desired. A very common guitar power amplifier topology is a long tailed pair driving a pair of tetrode/pentode connected output tubes. In this case because feedback is not used I would assume some extra care has been taken to assure good balance on the plates of the LTP. Plate resistors vaues would be chosen for highest possible gain, and might differ to assure approximate balance in the driver stage. Not unlikely that fixed bias was used on the output stage. Bias resistors would be as high as allowed for this topology. I'd go for 220K resistors and limit dissipation to less than 25W. Coupling caps should be sized to reduce the likelyhood of blocking distortion and might range from 0.015uF - 0.047uF max. Tetrode connection most probably and right off of the B+ at the point feeding the output transformer. (There are a few UL connected project guitar amps, but I have not heard one recently. UL might be better for damping in the context of an amplifier without overall feedback. I 'd try it both ways frankly.) Power supply probably not very stiff using something like 32uF input filter cap max. (my guess commonly available JJ cap or similar would be used.) I'd aim for right around 400V under quiescent conditions The tone stack would most likely be modelled after the Fender/Marshall stack (nee Western Electric) The tone stack calculator software at Duncan Amps should help you to design an appropriate tone stack. These are best quesses on my part, reading between the lines in the marketing copy. Small companies sometimes give things away in their marketing copy if you look closely enough. As always YMMV, and good luck!
www.kta-hifi.net |
#5 |
According to this: http://en.wikipedia.org/wiki/Mullard_5-10 The Mullard 5-20 was the one using the EL34..... |
#6 |
I'm pretty sure you don't want the 5-20 design, although there are hints in it of what you need to do.
www.kta-hifi.net |
#7 | |
lol.. I just noticed this was already posted... |
#8 |
Hope you find my reply useful, I am just curious enough at this point that I could probably be persuaded to do a tentative schematic, although I owe one on another thread I need to do first.
www.kta-hifi.net |
#9 | |
You needn't make a schemo, though... I'm really just casually looking into the design of the amp, from the perspective of my other thread needing an influence: Make: Bell P/A - Model: Carillon '35' |
#10 |
I'd use the carillon amplifier chassis to build one of these or just grab the power tranny. The opt is not going to be of any use. I'd expect a flame fest with that one in a guitar amplifier app, just too puny. Carillon amps are low duty cycle. I listen to carillon almost every day at Chautauqua during my summer visits - not exactly overtaxed.
Good luck.
www.kta-hifi.net |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.10591 seconds (88.29% PHP - 11.71% MySQL) with 11 queries |
