| diyAudio Sponsor | ||
Hi, guys. I want to build a simple SE amplifier with an output power of about ~ 1W. Can I use this tube in such a project? I'v heared verry good comments about it.
Regards: Venci
MY DIY AUDIO BLOG |
#2 |
It's a great tube for a linestage or driver. You can probably get 1 watt of power out of it, but the output impedance will be very high. Bass will be soft and woolly. Probably ok to drive Sennheisers.
jh |
#3 |
#4 |
Yes, 6S45P-E is one realy good piece of glass
Have you tried this design? The output power is quite enough for me
MY DIY AUDIO BLOG |
#5 |
No I have not tried it. With the low parts count you should be able to test it easily.
| 5687 fully balanced line stage | cedus | Tubes / Valves | 14 | 24th July 2009 01:28 PM |
| 5687 line stage | costa23 | Tubes / Valves | 35 | 10th August 2008 09:53 AM |
| Driving a 6B4G with a single 5687/7044/E182CC? | G | Tubes / Valves | 2 | 6th May 2007 11:29 PM |
| 5687 Line Stage | karma | Tubes / Valves | 16 | 3rd June 2003 09:44 PM |
| Anyone play with the Zen Single-Stage Single-Ended Class A? | Rino odorico | Pass Labs | 13 | 29th August 2002 09:01 AM |
| Page generated in 0.07106 seconds (70.37% PHP - 29.63% MySQL) with 10 queries |
