| diyAudio Sponsor | ||
#11 |
I can't disagree with the details Dave but don't see how that makes them worse than single-ended chokes which typically don't make it past the audio band either and are useless for RF filtering. Add to that the large size (and cost + shipping cost) required to avoid core saturation and I can't help think CM will do the job better and easier for less.
BTW, I like the 'couple hundred mH' idea too. Just can't see how to achieve low ripple without hundreds of uF to go with it. Gets really expensive wrapped around an 813. jayme, which Lundahl iron did you mean? All I see it audio stuff with pretty high DCR. |
#12 | |
http://www.lundahl.se/pdfs/datash/1638.pdf 10H 36ohms(is this low enough?) |
#13 |
Thanks. Now why didn't I think to check under TRANSFORMERS for chokes?
#14 |
Hi Dave Cigna
That's a long and nice explanation, although I must admit I don't understand everything. But I see part of your point...the fact people are using power toroids as OPT in PP amps is because the inductance is high enough for proper power at audio frequencies. In PS's the choke should eliminate HF stuff, then I don't know how well a toroid would work, ie, how much inductance is left...but I read the capacitance between windings is pretty low in a power toroid, compared to a power EI trafo. Hm...the inductance for a standard Hammond choke is specified at which frequency? I just bought 6x toroidals with 2x 115V primaries and 2x12V secondaries. I am planning a small amp ala "baby huey" using PL84 tubes for my hobby room: two of the toroids back to back for filaments and HV, two as OPT and two are left...but could be used as common mode choke. B+ would be around 250VDC. But that project won't start now, as I still have other ones to conclude first. Erik |
#15 |
Hi George
Have you conducted any further test with common mode chokes? Erik |
| common-mode chokes | jarthel | Tubes / Valves | 6 | 11th February 2008 03:31 PM |
| Common Mode Chokes for Heater Supplies | ppereira | Tubes / Valves | 7 | 29th January 2006 01:45 PM |
| Source for common mode chokes | abj1 | Tubes / Valves | 7 | 24th June 2005 06:31 AM |
| Using common mode chokes in filament supply. | G | Tubes / Valves | 8 | 9th December 2002 03:10 PM |
| Common mode chokes | Dr.H | Digital Source | 1 | 24th July 2002 04:47 PM |
| Page generated in 0.08515 seconds (71.47% PHP - 28.53% MySQL) with 11 queries |
