diyAudio Sponsor
Old 11th November 2006, 01:23 PM   #1
bembel is offline bembel  Europe
bembel's Avatar
Send a message via Yahoo to bembel
Question E182CC substituion ?
I am repairing a VTVM and have no replacement E182CC, Any substitutes (same pinout), at least, the time to debug & fix it.
Thanks.
Plus je pédale moins vite, moins j'avance plus vite !
Old 11th November 2006, 02:14 PM   #2
Sherman is offline Sherman  United States
The data sheet says "in many applications it is a replacement for the 5687" so that might be the place to start.
Check- http://tdsl.duncanamps.com/dcigna/tu...ex/7119-1h.gif
--Sherman
Old 11th November 2006, 02:45 PM   #3
bembel's Avatar
thanks Sherman
Old 11th November 2006, 04:01 PM   #4
Brian Beck's Avatar
Yes, the 7119 is the alternate part number. Although often mentioned as a 5687 substitute, the 7119/E182CC is really quite different (as is the 7044). If has a higher mu and higher gm, and the plate structure is significantly larger. Both it and the 5687 make nice audio tubes, by the way.
Brian
Old 11th November 2006, 04:03 PM   #5
Bembel,
A potential for pin out problems is present with the possible substitutions.
E182CC data sheet here.
6n30p data sheet here.
5687 data sheet here.
ECC99 data sheet here.
Eli D.
Old 11th November 2006, 04:11 PM   #6
bembel's Avatar
Thanks all, Problem identified, nothing to see with the E182CC, it was a dead Nuvistor! damned I have no spare.
Anyway your info is very usefull to get a spare one for the future.
5687=e182cc??? skybird Tubes / Valves 2 23rd August 2009 12:31 PM
6N6P or E182cc spice ikap Tubes / Valves 0 9th May 2009 03:59 PM
help for E182CC linestage/driver inertial Tubes / Valves 98 12th March 2009 03:35 PM
E182CC FTSIKIS Tubes / Valves 2 8th April 2007 02:13 PM
Why use E182CC? beamnet Tubes / Valves 10 23rd March 2006 12:28 AM
Page generated in 0.08927 seconds (77.10% PHP - 22.90% MySQL) with 10 queries
