| diyAudio Sponsor | ||
I can't seem to find this one elsewhere for some reason.
I know it's pretty basic stuff, but hey.. Basically, I want to learn the relationship between the AC from the transformer, the associated rectifier and the voltage that is produced. Any good links? BTW - I have left my "Valve Amplifiers" book somewhere between Connecticut and Pittsburg, so I won't have that as a reference until I order a new one. Thanks! |
#2 |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Wow!
Thanks, Leadbelly. |
#4 |
Here's a good reference:http://www.hammondmfg.com/pdf/5c007.pdf
#5 |
With no load the formula is very easy VDC = VAC * sqrt(2)
example 15Vac = 21.2 Vdc (after rectifier & caps) But in reality it needs to keep in mind the loss of tension on the rectifier and on inside resistance. bye |
#6 | |
#7 |
But you need to take into acount the voltage drop across
the diodes. Case in point I needed a 6.3vdc supply and had a spare 5v winding well 5v x 1.41= 7.05v which seems too high for my tubes but when built it prodused 6.12 v because ~1v lost across the diode. Woody |
#9 | |
#10 |
of course, only tube rectifiers are usable in tube amps...
| Calculating max Anode Voltage | b139b | Tubes / Valves | 0 | 31st January 2008 08:11 PM |
| calculating b+ voltage drop, decoupling? | jimytheassassin | Tubes / Valves | 7 | 10th November 2007 12:02 AM |
| Formula for calculating value of capacitor | klitgt | Parts | 15 | 17th February 2005 10:38 PM |
| Anyone have the formula for... | Rino odorico | Multi-Way | 4 | 22nd January 2003 04:07 PM |
| formula in calculating attenuation in a series configuration? | jarthel | Solid State | 1 | 21st July 2002 10:09 AM |
| Page generated in 0.10555 seconds (78.04% PHP - 21.96% MySQL) with 10 queries |
