Old 28th December 2002, 03:28 AM   #61
Wombat is offline Wombat  Germany
Wombat's Avatar
Has anybody else experienced any fetish behaviours when watching
audio circuits like this ?
If time permits - stuff some parsley in your ears and listen how it grows!
Old 28th December 2002, 03:52 AM   #62
Brett's Avatar
No, I have quite enough fetishes anyway. Keep me away from latex and leather.
Old 28th December 2002, 04:02 AM   #63
Wombat's Avatar
Ah! You are the guy i meat on the most dubiously areas!?
And no!! - I don´t crawl your earlaps with silver forks!
Old 28th December 2002, 04:27 AM   #64
Brett's Avatar
Isn't that a line out of the song "Blinded by the Light"?
Or are you reading Dr Seuss on halucinogens?
Old 28th December 2002, 04:38 AM   #65
Wombat's Avatar
I don´t read or listen anything clever!
No need of halucinogens, just some red wine...
cu Brett
Old 28th December 2002, 05:08 AM   #66
mrfeedback's Avatar
"When put on springs?
I find that odd, one would expect a less tight bass and less well defined stereo image.
Could be the type of floor plays a role, still...odd."
Frank, the Bostons are on my triangle shaped PC workstation table, each side of the PC monitor, and amplifier, vcr and tv are on shelves mounted above the PC monitor.
Without springs under the monitor, the table top buzzes like crazy at full level, and this vibration is also transferred to the amplifier.
With the speakers on springs, the table top is MUCH less vibrated, and the amplifier mounted on springs is motionless.
To my ear, the speakers are fuller, friendlier, and the system goes louder, and not the hardness in bass that is evident with other mountings.
In my workshop, the Cantons are mounted on springs on top a long shelf, at shoulder height.
All other mounting methods have resulted in rather high vibration of the shelf, and vibration of the electronics.
With spring mounting, the Cantons go way louder, stronger and cleaner, and ditto, no hardness in bass, and great imaging. (They are now vibrating the soles of my shoes when standing in my 140m2 shop).
I know that all of this goes counter to established standard doctrine, but since trying this, I find it hard to live with bass hardness evident with cones/spikes etc.
The key I think is that the box is allowed to 'float', and be its own system, without influence of delayed reflections from external mounting boundaries (floor, shelf etc).
The box is still sensitive to number and placing of the mounting points, and still requires placement tuning, but the criticalness is reduced, and I find I can tune up a better resultantant than I could using other mounting means.
"Could be the type of floor plays a role, still...odd."
Floors are always a strong influence in my experience.
The less coupling of box mechanical energy to the floor the better I reckon, because that leaves more energy to be emitted by the driver/enclosure system.
There is still more experimentation to be done, but so far I am more than satisfied with the results.
Eric.
I believe not to believe in any fixed belief system.
Old 28th December 2002, 08:43 AM   #67
vuki is offline vuki  Croatia
vuki's Avatar
Default sound of different materials
hi,
here is link to a very good article about the influence of different materials (mostly wood) on sound
http://www.vansevers.com/Tuning_Tweaks/System_Tweaking/system_tweaking.html
also; some interesting things about connectors and their influence on sound can be found in allen wright's "supercables cookbook"
Old 28th December 2002, 09:52 AM   #68
diyAudio Senior Member
fdegrove's Avatar
Default CORRECTION
If you don't mind here is the link again:
MIKE VANSEVERS
Frank
Old 29th December 2002, 10:59 AM   #69
mrfeedback's Avatar
Default So, I'm Not Nuts After All Then.......
Frank, thanks, good link, sorry if I missed it first time.
I have been and had a good read, and agree on most of what I read there, even if I do find some explanations a bit funny.
I have been down a similar track 10 years ago, and found similar things regarding wire/conductor direction, AC power feeds, and resonances, mechanical and electrical.
I found some similar soloutions, some different.
Seems you and I are not alone in noticing these effects.
Eric, The Vindicated.
Brett - Remember when you gave me a hard time when I dared mention the phrase "wire directionality" a long time ago ?.
He who laughs last laughs best.
Old 29th December 2002, 11:25 AM   #70
Brett's Avatar
Default Re: So, I'm Not Nuts After All Then.......
I don't recall that. I was probably taking the ****. I make all my own cables (and have for years), and always bring it off the spool, cut and align each conductor/length for direction. I don't think it's a huge effect (actually quite minor), but as they say God is in the details. Circuit topology is at least an order of magnitude more important.
Cheers
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 14th December 2007 11:41 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 01:20 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
Copyright ©1999-2013 diyAudio
