The sound of chassis?
Old 16th December 2011, 01:42 AM   #161
On Hiatus
SY's Avatar
The answer to that could fill a book. In fact, it did. Read "Building Valve Amplifiers," well worth the cost.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th December 2011, 01:45 AM   #162
a.wayne is offline a.wayne  United States
Sin Bin
Valves ... does that mean it has an steam engine ...... Will give it a look ... Amazon ?
Old 16th December 2011, 02:50 AM   #163
On Hiatus
SY's Avatar
Yes, you can get it from Amazon. Probably eBay as well.
Old 16th December 2011, 10:32 AM   #164
M Gregg is offline M Gregg  England
Isolation platform,
Two pieces of glass with bubble wrap in between…LOL
Don’t get using blue or black tack or hot glue under caps…the road to ruin.. LOL
Add some Sorbothane Sheet for good measure....perhaps not...
M. Gregg
Old 16th December 2011, 11:10 AM   #165
Just for interest,
You can get aluminium sheet with... not sure if its rubber or plastic sandwiched in the middle...no good for heat transfer but I guess another material for chassis bottom that has a damping effect. Quite strong...
I have seen lots of it not sure what its called...
Ummm tube dampers..mount the bases on silicon rubber washers..Then again mount the chassis base plate on silicon washers mount the feet to that...it goes on..
M. Gregg
Old 16th December 2011, 11:22 AM   #166
Just for interest,
I wonder what the shielding is like with the aluminium rubber sandwich it has aluminium on both sides. If earthed you have a double skin chassis..Phono stages etc...
I still like wood with some kind of metal foil Mu is probably best..or RFI tape..
M. Gregg
Old 16th December 2011, 12:00 PM   #167
Last comment..LOL
Just my thoughts...Chassis levels Power tx vibration eddy currents etc.
If components are on two levels ie top and bottom I like to ensure some mechanical isolation between ie different materials between bolted sections or some form of damping...gaskets come to mind... or something to stop ringing spreading across the structure. Main thing is to maintain good electrical integrity...and earthing. Passing cables through metal work or ferrite beads<<<if you put a supply cable through a hole in metal make sure the return comes through the same hole...if you don't you will heat up the chassis...Eddy currents come to mind.
I guess everyone has there own Ideas..
M. Gregg
Old 16th December 2011, 12:14 PM   #168
Just for interest..
http://www.roltesting.com/UserFiles/File/eddy.pdf
M. Gregg
Old 16th December 2011, 04:55 PM   #169
DF96 is offline DF96  England
Passing flow and return currents through the same hole is good practice anyway, but more important with a steel chassis as the ferromagnetic metal could couple different holes.
Old 16th December 2011, 07:03 PM   #170
Magz is offline Magz  United States
I did a lot of work on the LF EQ box for my Infinity speakers and was able to greatly reduce the noise level, as measured using TrueRTA. The noise level nearly doubled, however, when I put the steel lid back on the box; the effect was real and very repeatable, and corresponded to the frequencies emitted by the power supply. I'm thinking that the lid served to increase the noise transfer by induction from the PS half to the EQ half of the box, which are separated with a partition of TI-Shield (see picture). I wonder if making a lid from plastic to replace the steel lid would prevent that effect...
The sound of chassis?Hide this!Advertise here!
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 04:48 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 15th December 2007 12:41 AM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 05:28 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 02:20 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 06:37 PM
