#141 |
Here's what Shannon Dickson of Stereophile says about pneumatic platform. After trying it myself, I have to agree with every word he says:
![]() " In fact, it was the rather dramatic experience of hearing the sonic effects of pneumatically isolating a turntable and---surprisingly---a digital transport with the Vibraplane that led to this report, lest the relative sonic impact of these systems be confused with that afforded by more traditional means of equipment support. Before floating my source components with the Vibraplane, I was, like many of you, intimately familiar with the array of tonal changes afforded by various tuning devices. But by the time the stylus of my Lyra DaCapo cartridge had reached the inner groove of the first record played on my RPM-2 turntable after a Vibraplane had been installed beneath it, I had experienced a pronounced enhancement in the broadband resolution of my system that was very different in degree and quality from that offered by tonal manipulation alone. These benefits were turned out to be both predictable and repeatable with a variety of source components. I rank an even, natural tonal balance---with the emphasis on balance---as one of the most critical factors in true high-end performance. (This is to be distinguished from simply highlighting one area of the spectrum over another just because it sounds "better.") But I'm not anti-tweak. Creative experimentation has often led to real breakthroughs, even when the relationships of cause and effect are not well understood. Tonal alterations that make listening to a given system more enjoyable are perfectly fine in my book as long as the effect is not mistaken for, or promoted as, a de facto increase in fidelity. In my experience, those improvements which prove most fundamental and genuine tend to be consistent throughout the audible spectrum, conferring greater cohesiveness, refinement, and presence to the entire presentation. Tonal changes, particularly positive ones, are usually expressed with references such as "tight, focused bass," "good midrange detail," "extended and silky highs," etc.---all laudable individual attributes. But the kind of subtle yet significant improvement I'm speaking of breathes new life across the entire range of sonic attributes, enhancing every aspect of the musical experience. This is what happened to me with the Vibraplane. A certain synergy permeated the individual elements of the usual sonic checklist---and, in a way, superseded them. As a result, I found myself absorbed in one record after another, with barely a thought about sound quality. Clearly, sophisticated pneumatic isolation is a technique that deals with external vibration at a more fundamental level than the usual practices of rigid coupling and elastomer damping, and yet each of these methods plays a critical role in any comprehensive, logical, effective vibe-reduction plan."
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#142 | |
diyAudio Senior Member
Copper is very effective to combat EMI. RFI can be tackled at the input of the amp by means of filtering (usually this limits the bandwith too),a small .01 mF ceramic cap across the input is quite effective or the use of a steel enclure is very effective as well. Cheers,
Frank |
#143 | |
--Jordan |
#144 | |
Frank |
#145 |
One other way would be placing heatsinks inside the chassiss and use a sort of perforated steel panels around. But is the RFI so bad in your area, that you have to go through all that trouble?
#146 |
Here's how I build my RFI shielded Clone. I found an old amp, removed everything out except for transformer which is perfect for that purpose, cut the chassiss in half and with few mods and additions I have a very nice chassiss. I bought the amp for $50.
#147 |
And here how it looks with a top on. I only had to add side panels, front and rear. Everything else is reused.
#148 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#149 |
An old Dyna Reflex, pretty nicely built actually.
#150 | |
Account Disabled
| Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns | opc | Swap Meet | 6 | 1st May 2009 03:48 AM |
| What d'you put in the PSU chassis, and what in the circuit chassis? | andyjevans | Tubes / Valves | 5 | 14th December 2007 11:41 PM |
| How to star ground to Chassis without a Chassis?? | Minion | Chip Amps | 10 | 5th November 2006 04:28 PM |
| FS Gainclone Great Chassis, Potted toroidal, great sound | PHilgeman | Swap Meet | 4 | 2nd May 2006 01:20 PM |
| Where to get chassis or chassis parts in Vancouver? | Prune | Parts | 1 | 7th July 2004 05:37 PM |
