The sound of chassis? - Page 13 - diyAudio
Old 10th January 2003, 10:08 AM   #121
Originally posted by analog_sa
There are no such requirements for red book cd. Not enough error correction code to make up for all reading errors. And much more importantly there is jitter.
This topic has been discussed hundreds of times. Why don't you do some reading?
You know, there are CDROMs which can reliably do perfect DAE. Plextor stands as a front runner, although a lot of drives these days do just as good a job. Even for drives which don't do such an amazing job, there's tons of room for jitter correction at playback speeds.
I don't understand why instead of putting tons of effort into asymptotically approaching perfect extraction via case dampening, etc. people don't make up an interface with one of these drives and be done with the whole thing.
Old 10th January 2003, 11:03 AM   #122
analog_sa's Avatar
By making an interface i assume you mean something other than spdif. It's the silly interface with embedded clock that's probably the cause of 99% of the problems. I've tried some of the software based 'perfect' extraction proggies. If your CDROM is not capable of perfect extraction the softaware approach doesn't seem to work so well.
cheers
peter
Old 10th January 2003, 11:23 AM   #123
mrfeedback's Avatar
Default Excuse Me Sir, But Your Ignorance Is Showing...
"I don't understand how the air platform makes any difference with a CD player."
From a previous post -
I'll Say It Again.......
"Another scenerio where damping could be seen to benefit is: without damping we get more vibration on the disk making the laser mechanism work harder to track the disk. This causes more noise and load in the power-supply degrading the analog section of the player."
Yup, thats what I said earlier on .
Additionally, digital power supply fluctuation causes modulation of the analogue waveform datastream slicer (jitter), modulation of the clock oscillator (jitter) and modulation of timings in the DSP chip.
Seperated power supplies for servo, digital and analogue audio stages pays big benefits.
Mechanical damping helps, but the electronics require attention also.
Eric.
There are portable cd players that have a buffer memory such that the audio being decoded is delayed by two or three seconds after being read from disc.
This gives enough time for disc sections to be re-read if corrupted, and the disc spin speed is servoed to keep the buffer full (or near to full).
This buffer memory effectively isolates the focus and tracking servo induced power supply pertubations from the D/A and audio output stages, and allows substantially less jitter.
When servicing these players on the bench, when switched to normal operation, the audio output is similar to any other domestic cd player, but when switched to anti-shock buffer mode, the audio output is remarkably cleaner, sweeter and smoother due to substantial jitter reduction.
The signal coming off the disc is not a clean data stream, and the differences are in how the following stages behave, and much is to do with power supply cleanliness and earthing techniques.
Want some more ?.
Just do some searching or reading.
Eric.
I believe not to believe in any fixed belief system.
Old 10th January 2003, 03:36 PM   #124
grataku is offline grataku  United States
Analog
sounds like the biggest problem with red book cd format is that it is crap. Thanks for clearing that up for me. Since you seem to be up to date with the literature on the subject, do you know about how often/sec are we listening to interpolated music as opposed to what's recorded on the CD? I am sure the SONY and Philips engineers have tested and characterized the influence of vibrations on the reading mechanism before lauching the red book format, not that discovering how bad it was would have stopped them. Can you suggest relevant literature that is more technical and less anecdotal to better help me understand?
I have a genuine interest in understaning this subject and I apologize if I came off the wrong way. Thanks for slapping me back into line!
MrFeedback, my ignorance is deep indeed. I always thought I was listening to the corrected, checked and re-checked buffer signal. I wonder why it isn't so by default.
Old 10th January 2003, 04:18 PM   #125
Gabevee's Avatar
Grataku,
I understand your dilemma. However, the thing about vibrations in the reading of digital material is not in the mixing of signals as you mention with subsonic plus audible analog, but in the error correction the CD player now needs to undergo. I do a bad thing. I place my CD player right on top of one of my speakers and occasionally it will stop playing and resume due to vibrations of bass. But this is rare and only in my lab.
Basically, the error correction does an approximation of what the stored data is supposed to be rather than what it originally is. So the sound is different, or worse.
BTW, it is good to read that someone else also is aware of the presence of subsonic sounds and how it mixes with sound sources.
Cool!
What I would wonder is how, even though the table dampens vibrations travelling across the floor, the CD player doesn't vibrate from the sheer transmission of sound through the air, since he plays sometimes at full volume?
Gabe
Gabe CGV Electronics
Home of the CGV-300B amplifier on a budget
Old 10th January 2003, 04:50 PM   #126
Gabevee,
my basic dilemma comes from not knowing anything about this, really. I am not factoring the analog part, the servo part, into the equation at all which I thought was irrelevant to the software, digital part. The error correction by interpolation which, I think, is simply taking the preceeding and following point and averaging them to obtain the missing point in the middle, implies that there is a certain amount of "math" going on while the CD is reading this "math'" takes time to do. As a result, I thought that the sound was always buffered, that the interpolation was really the last resort to be used when repeat reading doesn't work, and that this doesn't happen on a continuous basis to completely change the overall character of the sound .
Old 10th January 2003, 05:05 PM   #127
mrfeedback's Avatar
Default Up To Date ? - Old News Really.....
"Since you seem to be up to date with the literature on the subject, do you know about how often/sec are we listening to interpolated music as opposed to what's recorded on the CD?"
Gabe, most mass procuced CDP DSP processor chips have error flag output pins, but these are usually left unused.
Some high end machines have front panel indication of different categories of data errors, but this is rare.
"MrFeedback, my ignorance is deep indeed. I always thought I was listening to the corrected, checked and re-checked buffer signal. I wonder why it isn't so by default."
Just a little bitch slapping you back to reality - nothing personal.
All cdps have a buffer memory, but on anti-shock machines the delay is much, much longer and this seems to make a big sonic difference.
These machines run an external (to the DSP chip) memory ic, and this is a cost function, of course.
"What I would wonder is how, even though the table dampens vibrations travelling across the floor, the CD player doesn't vibrate from the sheer transmission of sound through the air, since he plays sometimes at full volume? "
Because when the cdp is isolated, the only acoustic energy recieved is into the cdp cabinet itself, rather than being coupled from an excited shelf, which represents additional acoustical coupled energy, and further elimination of resonances between the shelf and cdp cabinet.
Old 10th January 2003, 05:35 PM   #128
mrfeedback's Avatar
Default Interpolation Is Audible....
" The error correction by interpolation which, I think, is simply taking the preceeding and following point and averaging them to obtain the missing point in the middle"
This causes a temporary halving in bandwidth. ...... Hmmmm I hear you say.
Eric.
Old 10th January 2003, 06:10 PM   #129
Default Re: Interpolation Is Audible....
Eric.
I enjoy a little 'bitch slapping' from time to time, keeps me awake. Now you have your chance to spank me, too.
No. Initially I'd say NO WAY, then I'd ask you what the hell is "temporary halving in bandwidth" then I'd say NO WAY again.
Please explain IN DETAIL what do you mean... Reciting the Nyquist Theorem won't do it. Learning is exciting.
Old 10th January 2003, 06:24 PM   #130
mrfeedback's Avatar
Default Let's Go To the Stoning.....
Ummm, I forget references and details (Panasonic training manual maybe ?) but whereever it was stated interpolation causes a halving in available bandwidth for the sample period concerned.
To think about it, linear interpolation is the intermediate average of the two outside sample points, and by definition this will cause halving of possible variation betwen the two valid samples (the before and after points) - halving of BW IOW.
Eric.
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 04:48 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 15th December 2007 12:41 AM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 05:28 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 02:20 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 06:37 PM
Copyright 1999-2017 diyAudio
