diyAudio Sponsor
Old 4th November 2006, 01:58 PM   #1
Send a message via AIM to selcuksiyoni Send a message via MSN to selcuksiyoni
Question audio research sp11 upgrade help please
hi to everyone,
ok I m new here - i read a lot here, then i said yesss! -I can do that to , i guess i couldnt . I tryed to upgrade my AR caps to 6 X 2.2 uf mundorf silver/gold + 2X 10 uf mundorf mkp+ phono input +phono output+cd input wires to 18awg jenalabs .sound was better problem is, after upgrade, i cant listen cd player when i turn my AR selector to cd or tuner i still hear turntable ,volume is changing to low or only one side ! i guess i mix the wires when i upgrade them any idea what i did wrong? or anyone has same preamp ,can look at the picture and tell me whats wrong with the wires please. (im using krell ksa100 MKII) thank you
Selchuk
[IMG]Click the image to open in full size.[/IMG]
Regards --- Selchuk
Old 4th November 2006, 04:32 PM   #2
Alain Dupont's Avatar
Selchuk,
If you didn't put labels on the wires before modifying...
At this point better get the schematic to verify all your connections.
Regards.
Alain.
Old 4th November 2006, 04:47 PM   #3
Gold_xyz's Avatar
look the schematics a this top-secret website
http://www.arcdb.ws/SP11/SP11.html
My English originates from here
Old 4th November 2006, 04:51 PM   #4
allready week I am looking at the schematics & I dont understand anythnk thats the problem ,
I told yaaaaa i am new ,I wasnt jocking when i say that
Regards --- Selchuk
Old 4th November 2006, 04:56 PM   #5
Gold_xyz's Avatar
Oooops, sorry..
Then I think that there is need of an electronic technician...
bye
schematic for Audio Research SP11? sean Tubes / Valves 10 12th January 2011 02:58 PM
Audio Research D-90 rudy129 Tubes / Valves 4 11th June 2010 01:19 PM
Audio Research St-70-c3 dcb50 Tubes / Valves 0 2nd October 2008 04:18 AM
Audio Research MCP 33 reinhard Tubes / Valves 12 2nd January 2006 06:04 AM
Audio Research Ls 2 ben goh Tubes / Valves 5 14th June 2002 07:51 PM
Page generated in 0.08477 seconds (66.76% PHP - 33.24% MySQL) with 10 queries
