diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Question on output hum on tube amp? (http://www.diyaudio.com/forums/tubes-valves/89538-question-output-hum-tube-amp.html)
andy2 2nd November 2006 06:04 PM
I wonder how high output amplitude would cause a noticable hum?
At 60hz, what would the voltage amplitude do you think would begin to give an audible hum?
Above 10mv?
bembel 2nd November 2006 06:12 PM
P=U/R ! , just figure out how much dB vs signal
hope this helps !
PS: In silence, as a rough guess I wouls say near audible with my ears (as 10mV@8ohm= 10W). though I didn't measured
andy2 2nd November 2006 06:41 PM
hope this helps !
So I guess your guess would be if you place your ear close enough, you will probably here it.
bembel 2nd November 2006 06:54 PM
yes, indeed
PS: just try to send an AF generator to a speaker to estimate (@60Hz or 120Hz for you) and just see ... (haven't time to do it now, but if you don't have a generator I can do it for you somewhere during the week).
andy2 2nd November 2006 07:56 PM
yes, indeed
I would appreciate it very much since I don't quite have the equipement.
Thanks.
andy2 2nd November 2006 07:59 PM
By the way, one more quick question, would 10 - 13mv of output noise be acceptable in a tube amp?
bembel 2nd November 2006 08:24 PM
have to measure, it depends, do you mean output on 8 ohm load, if not, then witch kind, RMS @ 60Hz ? How measured ?
andy2 2nd November 2006 08:57 PM
Measured @ 8ohm peak to peak @ assuming 120Hz.
Thanks.
SY 2nd November 2006 09:09 PM
OK, so that's about 3mVRMS, about -60dB below 1W. That's probably OK for speakers of normal efficiency, but I'd want to do better, especially if horns or high eff single drivers were being used.
kevinkr 2nd November 2006 09:34 PM
I traditionally design my personal amplifiers (where cost is not a consideration) for 1mVrms or less of residual noise including hum/ripple and hiss. This is acceptable in my experience with speaker systems to 103dBspl or so.
My current diy Onken speaker system is >96dB efficient and 300B based SE amplifier output noise is <0.5mVrms, obviously the noise is just about inaudible.
My noisiest design is around 3mVrms and with over 20Wrms per channel was designed for speakers in the low 90dB range. Hum was not obtrusive with a pair of high efficiency speakers (100dB+) but was audible during silent passages from a meter away.
I don't use global negative feedback in any of my designs so this has to be achieved by careful layout and good power supply design.
Copyright 1999-2017 diyAudio
