Question on output hum on tube amp? - Page 2 - diyAudio
Old 4th November 2006, 05:45 AM   #11
vax9000 is offline vax9000  United States
kevinkr,
How did you achieve the 0.5mV noise with the 300B tube? Did you use DC to heat it? BTW, I heard people saying that AC heated SET sounds better and I really don't know why.
vax, 9000
Old 5th November 2006, 12:04 AM   #12
kevinkr's Avatar
Yes, dc constant current heating which imho sounds as good as ac heating- at least I have not been able to tell any difference except that there is no residual hum..
I use ac heating on 2A3, 45 tubes, but find 5V and above dht really need dc heating to be hum free except in some pushpull applications where I have used ac heating successfully.
I know Steve Bench and others have deliberately injected hum into the output tube grid circuit to cancel filamentary hum, but the additional complexity and adjustments required discouraged me from following that path. The fact that it did not seem to work that well in a few amplifiers I have heard that used it was further demotivation..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
tube output chidpon Digital Source 1 12th October 2008 02:22 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 04:09 AM
Octal tube as headphone amp output tube yagoolar Headphone Systems 6 25th November 2006 10:11 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 06:28 PM
Output Tube biasing for Toroidal Output Transformer gingertube Tubes / Valves 7 17th April 2005 05:40 PM
Copyright 1999-2017 diyAudio
