| diyAudio Sponsor | ||
My amp began to smell of burning today, the 470 ohm resistor in the power line was obviously very hot and discoloured. There was also a distinct hum which I've never had problems with before.
Being new to Tube Amps could someone kindly point me in the right direction ? (I have some electrical background). Thanks in anticipation. |
#2 |
Hi Stephen,
Without being there or seeing a schematic, I can only give you the basics of what to look for in general order of preference. And I assume you mean a 470 ohm resistor in the B+ supply line. Not the AC mains. 1) Bad tubes, especially the output tubes. 2) Leaky coupling capacitors at the grid of the output tubes causing lowered bias and excessive current through the tube. (assuming you have fixed bias) Look for signs of tube overheating like a plate turning dull red. 3) Failing negative bias supply causing the same condition. 4) Leaky/failing power supply filter capacitors draging down the voltage level. Hope this helps. Victor |
#3 |
It's most likely to be leaky electrolytic capacitors. I refurbished a Cadet III a couple of years ago and after the first five electrolytics tested faulty when removed, I replaced the lot without wasting any more time in testing.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
Chers chaps, did some checking last night and yes the Electrolytics are leaking like a seive !
I'm now changing out the lot. Thanks again. steve |
#5 | |
Banned
Hey, Posted this on another thread but thought I should post here to existing owners of the amp
John |
#6 |
Banned
Plugged in Cadet III - it works!!! much to my suprise as it had been thrown into the bottom of a wire cage in the recycling centre ( I had toclimb in to retrieve it).
Anyway, a worthwhile find although it is noisy (Hiss & Hum). One ECL86 tube is hotter than the rest - will test all electrolytic caps & replace. Too soon to decide if I prefer tube to solid state. I can hear some potential (warmth,clear top end,etc) in the sound but maybe it's just not as precise as SS? |
#7 | |
#8 |
Banned
Thanks EC8010 - I also recycled from the same cage (although not at the same time) - three Samson Servo 550 solid state power amplifiers (all working), Ecler Smacpro40 mixer preamp, a Rega planar II turntable. I have only visited this recycling centre about 6 times & I often wonder what I have missed. It seems a shame that such useful & interesting equipment is being destroyed (I don't know what they actually do with it but I doubt it is refurbished).
Anyway, I will change the electrolytics & implement some of the changes you suggested on another thread - change 24uF smoothing caps for 47uF, change 100uF PSU caps for modern low ESR high ripple caps. There was also a mention somewhere about changing the biasing res from one shared 130R & bypass cap to 270R & bypass cap to each tube's plate(? - I'm not a tube guy so forgive me if this is the screen) Other discussions I read concern the PU adaptor - I plan to try to run the Rega planar II with high output moving coil cartridge into the Rogers Cadet III & using my Rogers LS3/5a speakers - might well be a nice system - it looks nice & retro anyway with all that wood on display. |
#9 | |
Magneto the Gravity Man
Most seem to through away!!!!!!!!!!!!!!!!!! Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#10 |
Our recycling centre has a sign saying that you're not allowed to take stuff away...
| Suggestions needed for improving Rogers Cadet II PP power amplifier | Sanjiv Sahgal | Tubes / Valves | 10 | 23rd May 2012 09:26 AM |
| Rogers Cadet III Schematics | needlesview | Tubes / Valves | 23 | 14th September 2007 08:50 AM |
| Rogers Cadet III schematics Corrections | jkeny | Tubes / Valves | 4 | 21st January 2007 08:23 PM |
| Rogers Cadet III PU Adapter | Jon Bradbury | Tubes / Valves | 16 | 19th January 2007 03:45 PM |
| rogers cadet mk3 hummm..... | boxenergy | Tubes / Valves | 1 | 21st April 2005 11:30 PM |
| Page generated in 0.12298 seconds (82.07% PHP - 17.93% MySQL) with 11 queries |
