6P14P Amp Scratch Build
Old 9th January 2007, 11:04 PM   #41
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
...sold. thanks
Old 9th January 2007, 11:26 PM   #42
Bandersnatch is offline Bandersnatch  United States
Default Re: nice work
Originally posted by jrdmedford
Also from Boston. We've talked before at some point. So whats
next??? I can help you out with getting better results with the
metalwork. I'm a whiz at FPE designer.
Amity Clones
The amps in the photo use MQ-565s, the Triode Electonics ST-35 power tranny clone. The itself is an Amity clone. I'm using 12AV5's strapped Triode (look like 2A3s), 6AX4 damper rectifiers and 12BH7 as drivers.
The top plates cost $170 to fab a pair (lots of countersunk holes). You can get the Walnut boxes for another $140.
For you next trick, you should do a Triode KT66 or KT88 PP amp.
-- Jim
Try the AV5 as pentodes. put g2 at ~70V. They do well as linestage tubes too. B+ of 200, g2 of 75, 100R cathode R and 750R plate loads....sweet!
cheers,
Douglas
the Tnuctipun will return
6P14P Amp Scratch BuildHide this!Advertise here!
scratch build EAR834p fallendragon Tubes / Valves 0 5th April 2008 02:47 PM
My 1st scratch build complete...... JandG Tubes / Valves 6 23rd April 2007 12:25 AM
My 6P14P Amp sorenj07 Swap Meet 1 9th January 2007 11:06 PM
First build from scratch. castlesteve Tubes / Valves 0 29th January 2004 03:33 PM
