diyAudio Sponsor
Old 26th October 2006, 10:43 PM   #1
Default aikido 12b4 input 6sn7 output???
OK, I am sourcing parts for my Aikido. I really want a low gain, as my power-amp seems pretty efficient with my speakers. So, I was thinking maybe of using 12b4 for the input (gain of around 10db) with 6sn7 outputs (gain of -0.5db) this would give an overall gain of about 9.5db.
What considerations are there regarding input tubes versus output tubes. Should such a low gain tube (as the 12b4) be placed as the input, with the 6sn7 as the output???
At some point, I'll have learned sufficient that I'll quit the (dumb?) questions, and maybe begin answering.
Thanks,
Charlie
Old 26th October 2006, 11:06 PM   #2
SY's Avatar
The gain you'll get from the Aikido is about 1/2 the mu. So first stage tube is an easy choice- whatever gain you need, twice that will be the required mu.
The output tube should be chosen for a high transconductance; the source impedance is proportional to 1/gm. 6SN7 is OK, not great in that respect. A look at the datasheet would suggest that you'd want to run it rich, 8-10mA.
I don't know any high gm octals off the top of my head, but maybe someone else could suggest one. For 9-pins, ECC88 is an easy choice. It's not the very best, but it's in that league and more than good enough.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Aikido 6SN7 input 5687 output eeyore Tubes / Valves 2 27th March 2009 09:17 PM
16SL7+6SN7 Aikido regal Tubes / Valves 4 7th July 2008 07:46 AM
Tube rectified LC PS for 6SN7 Aikido - choke DCR question LowRedMoon Tubes / Valves 3 20th June 2008 05:20 AM
12b4 vs. aikido linestage Klimon Tubes / Valves 2 14th August 2007 11:38 AM
tube hum in a 6SN7 Aikido - is this weird? cbutterworth Tubes / Valves 16 12th March 2007 04:52 PM
Page generated in 0.06289 seconds (73.08% PHP - 26.92% MySQL) with 10 queries
