diyAudio Sponsor
Old 25th October 2006, 06:44 PM   #1
bloozestringer's Avatar
Default DH rectifier hookup.
Easy question for you all and I just want to make sure this is how it's done.
When using a DH rectifier like a 5Y3GT, the power trannies secondary leads go to pins 4 and 6 with the PT's center tap grounded? Then the 5V filament leads go to pins 2 and 8, with the B+ connection to the first filter cap coming off of pin 8 or the B+ connection coming from the center tap of the 5V winding if it has a center tap (with the two main heater leads still at pin 2 and 8)?
Old 25th October 2006, 06:51 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
The +B can come off either pin 8, pin 2 but if the heater winding has a centre tap then use that.
Old 25th October 2006, 06:58 PM   #3
Yep. That's the way I was understanding it.
Thanks!
Old 25th October 2006, 08:12 PM   #4
tubelab.com's Avatar
If there is no CT (and even if there is) I use pin 8 as the B+ connection. That allows me to plug in a 5AR4 if I so desire.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 25th October 2006, 08:19 PM   #5
If there is a CT and you use pin 8 for B+, what do you do with the CT?
Old 25th October 2006, 08:52 PM   #6
Tom Bavis's Avatar
Tape or sleeve it and forget about it.
Old 25th October 2006, 08:54 PM   #7
I don't connect the CT to anything.
Using the CT on a DH rectifier will give you 2.5 volts less ripple (hum). Using the CT on a 5AR4 will give you 2.5 volts MORE ripple, and the DC output current will flow through half of the filament winding on the power transformer. So it really comes down to which tube you want to use more often. Either way will work.
Using pin 2 as the DC output on a 5AR4 will give you 5 volts more ripple and is not recommended (all of the DC output current flows through the filament winding on the transformer).
Old 26th October 2006, 05:05 AM   #8
Thanks everyone.
Every little bit adds to my germ-sized collective knowledge.
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
crossover amp hookup jonesk1978 Car Audio 2 26th February 2009 11:40 AM
6CJ3 rectifier or 6D22S rectifier 56oval Tubes / Valves 10 19th April 2007 09:48 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Page generated in 0.10283 seconds (68.39% PHP - 31.61% MySQL) with 10 queries
