max plate voltage rating in tube datasheet - Page 2 - diyAudio
Old 25th October 2006, 04:13 PM   #11
cerrem is offline cerrem  United States
cerrem's Avatar
dhaen is correct...
Most tube data sheets will indicate MAX Class A voltage....
Which really means the valve can really handle twice that voltage +20% .... SO iF your max Class A plate voltage is 400V DC... The valve should normally be able to AC swing to 800V with arc-over breakdown at roughly 1000V or so .....
It is really the sum of the DC idle voltage plus the AC swing that dictate where you can go with a valve.... This means that you need to watch the plate load swing if your running higher B+...
Many Push-Pull circuits run higher than data sheet voltage and can do so safely in Class AB... SInce each valve usually doesn't go higher than the rail then goes into cut-off, which is still lower than the full AC swig it would experience in Class A ....
Chris
Old 25th October 2006, 04:24 PM   #12
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
A much clearer and better detailed explanation. Thanks.
Plate Current VS Plate Voltage Graphs Captn Dave Tubes / Valves 2 13th February 2009 08:57 PM
voltage rating for Ci? rfenergy Chip Amps 10 21st June 2008 09:24 AM
Using a cap above its voltage rating? h_a Parts 10 6th October 2007 03:46 PM
76 operating point/max plate rating? kegger Tubes / Valves 7 3rd December 2006 04:50 PM
does plate current/voltage effect tube sound???? benny Tubes / Valves 10 7th July 2004 01:18 PM
Copyright 1999-2017 diyAudio
