| diyAudio Sponsor | ||
I'm considering to use c3m pentode as driver for a 7236 dual triode se, the latter needs 100Vpp swing and the former can deliver 115Vpp BUT When calculating the low pass -3db point due to miller capacitance I get around 19khz = not good. What baffles me is that the c3m gets used by several people to drive a 300b; relevant c3m variables won't differ much in those circuits and in mine (260V B+/10K load/ ca. 200k Ri) AND the 300b has even worse Cag than 7236 (15 vs. 10)... So... Could anyone shed a light on this enigma? Is c3m-300b a bad miller capacitance mariage or should I practice a little harder on my miller calculations (probably!)? Thanks alot!!! Simon |
#2 |
Excellent question. Very relevant to a project I have going. Woud also love to hear some insight.
#3 |
http://www.diyparadiso.com/triple1.htm
Triple 300B, c3m driver = 3* miller capacitance Still chewing on the same teaser Simon |
#4 |
Well... on Benny's triple 300B design, if I calculated correctly, I get a f(-3dB) of around 23kHz.
You have to include the plate load resistor of the pentode (none, in Benny's design, as it has a plate choke) in parallel with the grid-ground resistor(s)s on the 300B(s) (a total of 27.5k in this case) in the output impedance of the driver. This dominates the Zo of the driver, but it is also in parallel with the Rp of the pentode. On the single 300B, freq response depends on what those resistors are. With a typical resistive load on a c3m there should be no problem... Pete |
#5 |
thanks a lot Pete, I put the plate load and Rp in series in my calculations... c3m looks perfect for the job
Simon |
#6 |
Did you put the load load resistor and the tube rp in series or parallel? The C3M source impedance is actually the thevenin equivalent of rp and the plate load resistor in parallel, not series. This incidentally would improve the picture still further.
www.kta-hifi.net |
#7 | |
Simon |
| Pentode Miller Capacitance, and which spec value to use? | flysig | Tubes / Valves | 5 | 30th May 2009 08:59 PM |
| 71a Line Stage and Miller Capacitance | dsavitsk | Tubes / Valves | 32 | 2nd November 2006 12:19 AM |
| Why does the 6AS7 have such high Miller capacitance ? | Shoog | Tubes / Valves | 11 | 18th September 2006 09:17 PM |
| Ultralinear Miller capacitance | rdf | Tubes / Valves | 3 | 9th July 2005 03:18 AM |
| Miller capacitance | ding | Solid State | 11 | 28th September 2001 07:01 AM |
| Page generated in 0.09138 seconds (77.03% PHP - 22.97% MySQL) with 10 queries |
