The perfect phono preamp.
Old 25th October 2006, 01:41 AM   #11
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I just love red glowy things.
Unless they are resistors, or plates.
That is usually the case for me.
Hey! Wait! I thought resistors just smoked and caught on fire.
I have proven that the white ceramic sand filled ones can glow red, and survive! So can the old green ones. And that Electro Harmonix KT88's can glow red and blue at same time all while sounding pretty good.
Seriously, it is time for a new phono stage. My current one is getting pretty noisy, and it is not the tubes.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th October 2006, 10:25 PM   #12
ErikdeBest is offline ErikdeBest  Switzerland
Frank presented two RIAA stage together with the 12BH7A WCF. Both have two stages build around the 7025. SY would say it has got to few tubes...Morgan Jones explains why, in the third edit...blabla
Morgan Jones's balanced RIAA preamp got 8 tubes per channel. Some are used as CCS, but there are still two sand CCS's in there, so anyone interested could hit the 10 tubes/channel figure - or even go beyound that - maybe with a tube regulated PS, but afther this
It certainly instructed me to run from tube regs at full speed.
I will shut up!
Erik
Old 26th October 2006, 12:30 AM   #13
On Hiatus
SY's Avatar
Mine has 4 tubes. Oh, yes, and 12 FETs... that should put off about 99% of the intended audience.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th October 2006, 12:49 AM   #14
Geek is offline Geek
Geek's Avatar
After a week designing, I have one almost completed. All tubes, curve is perfect, sounds good, gotta make it sound great before posting
Not a dang 12AX7/7025 in it either
Old 26th October 2006, 12:53 AM   #15
On Hiatus
SY's Avatar
I gotta see this! Will you be showing off the goods?
Old 26th October 2006, 01:24 AM   #16
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
My friend made a phono preamp with six 407A and 4 ECC88 tubes in there The chassis is too big, made of stainless steel, and the power supply is bigger than as 1200VA APC UPS
Sy, are those FETs readily orderable? From RS Compnents perhaps? C'mon tell me the tubes So I will have time to find 4 of them
Old 26th October 2006, 01:31 AM   #17
On Hiatus
SY's Avatar
I've never dealt with RS so I honestly don't know. I got mine from Mouser (Supertex DN2540). You'll need to order extras to accommodate matching; I got 100 of them, split them with a friend, and had no trouble putting 6 matched pairs together from the 50 I kept. At about US$1.50 each, that's not too prohibitive.
Old 26th October 2006, 02:08 AM   #18
astouffer is offline astouffer  United States
astouffer's Avatar
Speaking of preamps, any thoughts on this one?
http://margo.student.utwente.nl/el/t...p/fb-e180f.gif
Not sure where its from but its been on the internet for a long time now.
Old 26th October 2006, 04:08 AM   #19
Geek's Avatar
You betchum!
E180F is a great tube, but I've only used it trioded. The EQ method I haven't tried.
Old 26th October 2006, 09:06 AM   #20
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
That's interesting, because I am designing a phono amp too. An hybrid casconde on the input, the lower device being a single fet for MM cartridges, and a quartet of bipolars for MC cartridges. Passive RIAA (SPICE says ±0.05dB flat from 10Hz to 20kHz) and then CCS loaded ECC88 stage (but I'm not sure about it). Will drive an Aikido linestage in the same chassis, 6CG7 + 5687 tubes
The perfect phono preamp.Hide this!Advertise here!
Pumpkin Preamp - Perfect for F4 Zen Mod Pass Labs 882 28th July 2017 08:13 PM
Copyright ©1999-2017 diyAudio
