Got my 6BG6GA's last night
Old 24th October 2006, 11:43 AM   #1
Burnedfingers is offline Burnedfingers  United States
Default Got my 6BG6GA's last night
After hearing SY speak a while back about the 6BG6GA's he was using in some of his amps I was moved to order a matched quad of them and (4) of the put together adapters. Very nice tube indeed and the price is well within anyones means. The site I purchased them from claims they ran them on 500 VDC plate and I think 450 VDC screen. I believe they are rated at 35 watts.
Could I try these in my Quicksilvers that run about 478 plate and run 50mA each thru them? That would be about 24 watts?
Thoughts?
Old 24th October 2006, 12:31 PM   #2
On Hiatus
SY's Avatar
That should work, but check the plate-to-plate impedance of the transformer. At that operating point, these work better with 6600 than 4000 ohms.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th October 2006, 01:06 AM   #3
I'm looking at about 4300
Old 25th October 2006, 01:08 AM   #4
On Hiatus
SY's Avatar
It'll work well in pentode, but that's a bit low for UL or triode.
Old 25th October 2006, 01:58 AM   #5
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Sorry if you think this is inappropriate, but I bought the same tubes on SY's recommendation and still am hemming and hawwing about how to use them.
My most recent idea is the following, a 6EJ7/6SN7 Aikido, the idea being that it'll be relatively easy to implement since I think I can cram 2 of the small pentodes into the 1st tube position on one of the Group Buy octal PCB's, plus I already have these tubes. Gain is a little low, only about 30 by my calc, but will it have the oomph to drive these tubes?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 25th October 2006, 11:53 AM   #6
You may want to put this in the Aikido thread where it will be seen and enjoyed. Nice idea well worth trying. I would love to try it but I don't have any 6EJ7's.
I probably just shot the price of that tube up an ebay.
Old 25th October 2006, 08:16 PM   #7
leadbelly's Avatar
OK by me, I bought my lifetime supply a while ago.
Old 3rd November 2006, 04:04 AM   #8
wrenchone is offline wrenchone  United States
wrenchone's Avatar
One thing I don't really understand about these hormone enhanced 6BG6GAs is whether thaey are really high perveyance sweep tubes or 6L6GCs in disguise with a top hat? Is the screen grid high gain like in a sweeo tube? I was thinking of dropping a pair of these in my 6CD6GA enhanced triode SE amp after I have it up and running for a while. From the sweep tube specs it looks like I would be better off using it in standard triode strapped mode due to the higher screen voltage rating, though I would have to completely retune the bias circuit to match the higher sensitivity. I bought a dozen - the price was too low to resist.
Old 3rd November 2006, 04:09 AM   #9
On Hiatus
SY's Avatar
These are much more like 6L6GC. In fact, probably identical. The guts and the way they performed in two amps I used them in seem to ape the 7027As that I used to use back in the day.
They are definitely NOT high perveance sweep tubes.
Old 3rd November 2006, 09:09 AM   #10
coresta is offline coresta  France
coresta's Avatar
Hi, make a "search" in DIY archives and you'll see that 6L6, 807, 6BG6 are the from the same juice . The bottle may differ , the plate , the cap , the pinnout too , but all of these are the 30'
Got my 6BG6GA's last nightHide this!Advertise here!
Simple SE and 6BG6GA's whitelabrat Tubelab 18 25th October 2011 05:46 PM
6BG6GA adapter instructions needed Burnedfingers Tubes / Valves 19 4th October 2011 12:52 AM
blue led at night wuffwaff Everything Else 34 17th September 2009 09:16 PM
KT66/6L6GC/5781 6BG6GA replacements. gregaz Swap Meet 0 16th February 2008 03:54 PM
Night dreaming? / Middle of the night bloom Gabevee Tubes / Valves 54 25th July 2004 05:36 AM
