diyAudio Sponsor
Old 24th October 2006, 01:52 PM   #11
Brian Beck's Avatar
The 12Meg and 1000pF feedback parts are a bit perplexing. The 12Meg will provide only a slight degree of feedback in the very lowest frequencies. If the open loop gain were infinite this resistor would need to be about 1.2Meg to give the requisite 60dB or so of gain in the low end, but since open loop gain is finite, this resistor has to be larger than 1.2Meg, hence 12Meg. Besides, above about 13Hz, the 1000pF will dominate, so that most of feedback in the audio band runs through this cap. This large resistor may also participate, along with the 1000pF cap, in adjusting loop phase shift to prevent low-end instability due to too many coupling time constants enclosed in one feedback loop. Simulation would provide more insight if you are really interested.
This is conjecture, but perhaps the designer also felt that biasing the feedback caps with DC would improve their performance. So the 12Meg would provide a DC path to keep the 100pF, the 270pF and the 27pF biased above 100 or 150 volts. Also, at the top of the audio band the 0.47uF output coupling cap is enclosed in a feedback loop by the presumably superior 1000pF cap which is 470 times smaller. Possibly the designer figured any distortion the 0.47uF cap might make would be eliminated by this feedback.
Or, maybe the designer just threw parts together until it all seemed to work OK
Brian
Old 24th October 2006, 10:22 PM   #12
diyAudio Senior Member
fdegrove's Avatar
As I don't have sufficient knowledge to figure out feedback loops by just looking at them I was thinking along the same lines as you point out in the second paragraph. I do doubt however that any designer from that era was concerned about polarizing caps in the FB loop but you never know....
Either way it's a neat little trick.
Frank
Old 30th October 2006, 12:36 PM   #13
soulmerchant's Avatar
Ok.
I figured out what the humm was. If you physically move the power supply away from the pre-amp the humm goes away. The 220 uf B+ caps are probably not low esr and are getting close to 20 years old.
I will replace these caps in any case.
What is really interresting is the power supply itself though.
Two separate voltage doublers (one for each channel) - ok not so special... but a highly regulated filament supply using solid state.
I will post the schematic if there is interrest, but why regulate the filament supply so much?
The transformer is dated Aug. 1986. and has no other markings (made in england though you can be sure of that).
Th. Lösch Phono Amp: Question about IC used & ECC808 to ECC83 Herr Grau Tubes / Valves 45 23rd February 2009 11:12 AM
Telefunken ECC83 / 12AX7 Used (Old Stock) sorenj07 Swap Meet 2 6th January 2009 03:02 PM
ECC83/12AX7 Tube test query waam68 Tubes / Valves 8 8th November 2007 07:52 PM
Fun circuit with a 12ax7 (ecc83) ebijma Tubes / Valves 7 20th April 2005 07:33 AM
RIAA phono preamp using single ECC83 DJG Tubes / Valves 19 29th March 2003 02:27 PM
Page generated in 0.09138 seconds (76.67% PHP - 23.33% MySQL) with 11 queries
