| diyAudio Sponsor | ||
#61 |
Hi tubeholics
cheers
#62 | |
(The same stores chap came out of retirement and got a part-time job at Conrad-Johnson just as they were designing a new valve line stage...)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| High Voltage Regulator Design | dsavitsk | Tubes / Valves | 45 | 21st November 2011 03:05 PM |
| Voltage Regulator design LM317T 70V to 20V | mhamzah3 | Power Supplies | 4 | 27th August 2008 09:01 AM |
| tube voltage regulator error amp | nhuwar | Tubes / Valves | 14 | 20th May 2008 10:38 PM |
| Tube Voltage Regulator Flicker... | sonata149 | Tubes / Valves | 14 | 3rd March 2007 07:22 AM |
| Tube for a shunt voltage regulator | jarthel | Tubes / Valves | 14 | 26th October 2006 04:19 AM |
| Page generated in 0.05722 seconds (78.56% PHP - 21.44% MySQL) with 11 queries |
