JE Labs 300b round 3. Chassis are Done
Old 21st December 2002, 12:51 AM   #1
TubeHound is offline TubeHound  United States
Default JE Labs 300b round 3. Chassis are Done
Hello Everyone,
Well, this is my best effort at making chassis from scratch. I will need help making sure I solder all the wires correctly and get the polarity right on some of the parts. These are my first DIY audio amps. Hope these inspire some other new person thinking of doing thier own DIY project.
Old 21st December 2002, 12:52 AM   #2
Default back
back
Old 21st December 2002, 12:53 AM   #3
Default front
front
Old 21st December 2002, 01:23 AM   #4
cadman is offline cadman
cadman's Avatar
Paul, those chassis look great! You did a nice job with those corners too. Just curious, where did you pick up those octal sockets? AES?
Cory
Old 21st December 2002, 01:55 AM   #5
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
JE Labs 300b round 3. Chassis are Done Send a message via AIM to Peter Daniel
This is very nice chassis. Did you have any problem with those round holes?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st December 2002, 02:57 AM   #6
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Absolutely beautiful! What kind of wood did you use for the chassis?
Brian
Old 21st December 2002, 03:11 AM   #7
First, Thank you for the compliments everyone.
Hi Cory,
The sockets are Yamamoto's teflon. One is a UX4 for 300b, one a UX5 for 76 type and two are octal for a GZ37 and 6SN7. The majority of the wood is 3/4 solid walnut harvested and milled by a local. The corners are tulip wood from South America and made using an Incra dovetail jig. I capped all the corners with the tulip wood to fix some mistakes and it came out better than expected.
Hello Mr. Daniel,
First I must say I am in awe of your work and you have certainly inspired me with some of your ideas. The holes were tough, very tough. I laid out the dia. with a compass, then drilled little holes completely around the inside edges. I then used a dremel tool with a cloth reinforced cutoff wheel to connect the little holes and drop the center out. Next, using a electric hand drill I used a small diameter metal cutting bit to cut through sharp ridges left. Once they looked round, I used drum sanders , varying in size from 1 inch to 2 1/4 inch, that mount into the drill to round the holes, checking with a dial caliper to make them fairly uniform. They might vary by 10 to 20 thousands.
Old 21st December 2002, 03:30 AM   #8
Brett is offline Brett
Brett's Avatar
Default Ugly and dangerous
You should send them to me <i>immediately</i> for safe disposal.
My mdf chassis are blushing.
Old 21st December 2002, 04:11 AM   #9
jainbaby is offline jainbaby  United States
Default Make me some
Are you going to make any? I want the first one if so.
Steve
jains@panasonic.com
Old 21st December 2002, 05:08 AM   #10
Now, I must say that I am in awe of your work. 10-20 thousands is damn good accuracy.
This type of bits are useful for trimming curves in soft metals, especially if you use it with a 90 deg. grinder.
Did you protect copper somehow?
www.audiosector.com
JE Labs 300b round 3. Chassis are DoneHide this!Advertise here!
JE Labs 300b round 4. Wiring, HELP!!! TubeHound Tubes / Valves 49 27th June 2003 11:08 PM
JE Labs 300b round 2! layout TubeHound Tubes / Valves 12 13th May 2003 09:46 AM
JE Labs 300b round 2 1/2 Copper Plates TubeHound Tubes / Valves 18 9th April 2003 01:30 AM
JE Labs 300b round 5. MUSIC!! MUSIC!! TubeHound Tubes / Valves 14 11th January 2003 01:02 AM
Je labs 300b round 1 : Ding! Ding! TubeHound Tubes / Valves 9 13th October 2002 09:28 PM
Copyright ©1999-2017 diyAudio
