#11 |
Here's a better view.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#12 |
Hi Peter,
The bit on the left is what my metal cutting bit looks like. It was a cheapy though and seems to wear fast. I mounted the copper in my wood working vise to hold it vertical while I worked on the holes. Once they were all done I spent about a week polishing the plates to remove all the scratches. I wanted a mirror finish, but a local plating shop quoted me $450.00 just to polish them. I used my 8 inch bench grinder and a buffing wheel with compound to get close and then brushed them with 3M metal sanding pads by hand to achieve the brushed look. I coated them with a clear acrylic, non yellowing, paint. Four coats. Hi Steve, I have entertained the thought of making some wood bases, but no metal work. Metal is much harder to work without the proper tools. I own a fairly extensive collection of wood working tools and that is one of my hobbies. Now if I could make serious dollars and make enough wood bases, I could buy a CNC knee mill and metal lathe, tooling and be in the chassis business. I am dreaming Hi Brian and Brett, Thank you for the compliment. |
#13 |
diyAudio Senior Member
Paul,my sincerest congratulations. Fabulous looks,really. While we're at it does anyone use as punching kits for sockets and such? GREENLEE Look at the right:"Holemaking" I find these very handy to have unless you need to do this kind of work on a daily basis. Any material except very hard and thick (>3mm) steel works very well,moreover it fits tubesockets perfectly. Nice work,
Frank |
#14 |
Chassis look great!!!
A very professional job that you can be proud of! Joe |
#15 |
OH-MY-GOD.
I love that chassis! Great work! |
#16 |
Very nice work, BTW are you in fine furniture by trade?
Great piece of art Chris |
#17 |
Hi Chris,
No, I am in the fine grading trade, Heavy Construction. I am a Journeyman Heavy Equipment Operator. I am some what of an artist at my job. I do finish work with a motor grader and operate several other pieces of equipment equaly well. Doing it for 24 years now. Just obsessed with everything I do. |
#18 | |
Congratulations Paul! Keep that spirit. and show us the finished amps.
| JE Labs 300b round 4. Wiring, HELP!!! | TubeHound | Tubes / Valves | 49 | 27th June 2003 10:08 PM |
| JE Labs 300b round 2! layout | TubeHound | Tubes / Valves | 12 | 13th May 2003 08:46 AM |
| JE Labs 300b round 2 1/2 Copper Plates | TubeHound | Tubes / Valves | 18 | 9th April 2003 12:30 AM |
| JE Labs 300b round 5. MUSIC!! MUSIC!! | TubeHound | Tubes / Valves | 14 | 11th January 2003 12:02 AM |
| Je labs 300b round 1 : Ding! Ding! | TubeHound | Tubes / Valves | 9 | 13th October 2002 08:28 PM |
