diyAudio Sponsor
Old 22nd October 2006, 12:17 AM   #1
jayme is offline jayme  United States
Default aikido thump
Anyone else get a loud thump when turning off their aikido-based preamp?
Just wondering if the issue is with my PSU section...
Old 22nd October 2006, 01:50 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
It is reportedly common practice, among those who use separately powered preamps, to switch off the main amp first, wait a second or two, and then switch off the preamp.
Old 22nd October 2006, 02:02 AM   #3
Yeah...I am familiar with that practice...but I'd like to look for an overall solution other than a guideline (my wife likes to shut everything off at once...)
Old 22nd October 2006, 03:11 AM   #4
I put an idiot sheet next to the equipment. It spells out the turn on and off procedure.
Problem solved
Old 22nd October 2006, 07:27 AM   #5
Andypairo's Avatar
I use a relay that shorts out the output (after the cap) with its NC contacts.
I energize the relay after a delay at turn on and de-energize it immediately at turn off.
No thumps.
Cheers
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 22nd October 2006, 08:37 AM   #6
triode_al's Avatar
Default Re: aikido thump
jayme
In my Aikido I have a 1.200 micro farad capacitor at a 215 V. It takes some time to load and similarly - to unload.
The result is: no thumps on turning on, and no thumps on turning off. It just fades (the tubes are cold befor the power line really drops).
I switch my power amp with the power switch of the Aikido. My power aplifier is transistor (LeMonstre) and would really show up any odd issues. Maximum at turn on is 3 volts for 1 second at turn on (after 30 sec) and none at turn off. For safety, you should really add Andy's relay.
success
albert
See my 2SK175/2SJ55 F5.. CS8412/SAA7220/TDA1541 ; SP-6 Light ; MC30 Super--> two stage RIAA 2SK240-ECC88/6SL7.
Old 22nd October 2006, 03:13 PM   #7
How would I implement a relay? Just have a switch which shunts B+ thru a resistor to ground?
I don't need the protection at start-up...I use a 5AR4 rectifier, which gives me a slow ramp up.
My PSU doesn't have a lot of big caps: it is CLCLC with 3.3uF, 20uF, and 40uF caps, respectively. I use some big 15H chokes for the inductors.
Old 23rd October 2006, 03:32 PM   #8
Klimon is offline Klimon  Belgium
I put an idiot sheet next to the equipment. It spells out the turn on and off procedure. Problem solved.
Old 24th October 2006, 12:29 PM   #9
Andypairo's Avatar
I was talking about shunting the output (=signal) after the coupling cap.
Cheers
Andrea
Old 26th October 2006, 01:30 PM   #10
Bill*B is offline Bill*B  United States
My own Aikido has a subsonic output at turnoff - you can see the speaker cones thrust out, although there's no sound. I've never tried to track down the source, although I (like you) suspect that it is the power supply - I used a regulated unit and I'll bet the voltage surges when the voltage reference falls out of conduction.
Aikido users- anyone NOT have turn-off thump? jayme Tubes / Valves 19 14th October 2007 04:07 PM
turn off thump jayme Tubes / Valves 6 23rd September 2007 07:40 PM
What is that thump,thump,thump? 65blkbkgt Car Audio 7 17th June 2007 01:35 AM
On & Off Thump Kinger Chip Amps 2 31st December 2006 11:46 AM
Anti-thump suzyj Solid State 15 21st October 2006 01:03 PM
Page generated in 0.11204 seconds (79.09% PHP - 20.91% MySQL) with 10 queries
