diyAudio Sponsor
Old 20th October 2006, 02:38 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default LM329 as voltage referens in a CCS
Any one tryed it,does it have the same drawbacks as a Zener (noice e.t.c)?
Regards Åke
Old 20th October 2006, 05:01 PM   #2
SY's Avatar
It's quieter than most zeners (take a look at the datasheet for noise density curves). Very stable. Lowish current.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th October 2006, 05:28 PM   #3
Ryssen's Avatar
Ok,I thought of trying it in a CCS instead of a Led,is there any gain in bypassing it?
Regards Åke
Old 20th October 2006, 05:55 PM   #4
SY's Avatar
It will probably be noisier than a LED. As far as bypassing, that depends on the details of the circuit you're using it in; you have to see what the impedance at that point is and if any reasonably sized bypass will get you a significant improvement.
Old 20th October 2006, 06:04 PM   #5
Ryssen's Avatar
Well the circuit is:
I read in the pdf file for the CCS that I could make it better by using the LM329 for the first Led,but if you say it is noisier maybe it´s not an improvement?
Regards Åke
Old 20th October 2006, 06:14 PM   #6
SY's Avatar
A 329 will give you 6.9V, so the emitter resistors would have to be adjusted accordingly. What the extra voltage gets you is those larger resistors and hence higher output Z from the CCS.
Noise shouldn't be an issue- it's divided down by the ratio of the CCS source Z to the plate resistance of the tube.
Old 20th October 2006, 06:41 PM   #7
Ryssen's Avatar
Ok,It´s worth a try then,will it hurt to bypass with a 0,1 filmcap?
Regards Åke
Old 29th March 2007, 03:22 PM   #8
jackinnj's Avatar
After reading the WJ article in AudioXpress I switched to a LM329DZ + 2N5639 + 2N5089 Reference -- (WJ used LM329 + J113 + PN2222A.)
I haven't done a noise test on this yet but the graph in the article was pretty impressive -- here's the circuit and some data:
Old 29th March 2007, 03:55 PM   #9
Fanuc is offline Fanuc  United Kingdom
Hello,
We would need to see the Zout versus frequency plot. (50khz plots would at least cover the audioband! Ho Hum!!) . Also any capacitances from PCB's & wiring etc will reduce this. The Zout for higher current looks attrocious - even compared to ring of two at high currents. A good one I seen was two LM329 in series biased by a J50* and then two bjt's cascoded. This is the best I have seen in terms of Line Rejection.
Max Zout doesn't neccesarily improve Line Rejection (or there is some competing mechanism) - Witness cascoded jfets etc. I have seen some Jfet CCS's with >100M Zout at LF but PSRR was about 85db and diminished greatly at HF. See what I mean.
I think from what I have read that very low gm FETs are best for current sources. Plus could be RC filtered for lower noise.
Best Regards
Kevin
Old 29th March 2007, 06:50 PM   #10
jackinnj's Avatar
Did you see the article? This is the actual circuit which has an equivalent impedance of 1.8MegOhms...ymmv
LM329 Voltage Reference fatmarley Parts 8 29th November 2007 03:46 AM
Need AC voltage reference johngalt47 Parts 18 12th April 2006 08:59 PM
voltage reference for 16bit dac (LM329 ?) ash_dac Power Supplies 6 8th April 2006 03:19 PM
CCS Voltage Reference Kashmire Solid State 1 24th January 2005 07:25 PM
LM329 Precision Reference usage Zodiac Parts 0 23rd July 2003 10:05 PM
Page generated in 0.10429 seconds (87.07% PHP - 12.93% MySQL) with 10 queries
