6N1 Chinese tube and others
Old 15th November 2012, 11:00 PM   #21
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
6N1 and 6N1P circuits can usually take 6922. Sometimes would require circuit adjustment, but worth a try.
Old 9th August 2013, 06:23 PM   #22
keithsplace is offline keithsplace  United States
Default Try thissite
Great tube substitute site.
http://www.worldtubecompany.com/mm5/...mvc?Screen=TSL
Don't have data sheets but it'll give you a start.
You have to look at China tubes to find the 6N1
It says that equivalent is
6N1P, 6N1P-EB, 6N1P-EV
Old 10th August 2013, 11:15 AM   #23
v4lve lover is offline v4lve lover  Netherlands
Urban myth. 6N1P is a normal tube ECC88/6922 is a frame grid.
I have both of them, and I have tested them. the 6n1p is an entirely different tube. that their pin compatable and will work to some extent seems only to keep the myth alive.
6N1P Is suited to do anything a 6sn7 will do in audio circuits.
Old 11th September 2013, 08:06 AM   #24
Default How about the Chinese 6J1
Is there a good replacement for the China 6J1 valve?
I want to try some different tubes in a Little-Bear P5.
I heard that the 6554W JAN's is supposed to work and have better sound.
Old 11th September 2013, 09:24 AM   #25
jazbo8 is offline jazbo8
jazbo8's Avatar
From the Chinese tube manual, the following can be sub'd for the 6J1 (please verify the actual specs yourself): 6AK5, 6F32, 5591, 5654, EF40, EF95.
Old 11th September 2013, 10:36 AM   #26
DF96 is offline DF96  England
EF40? Different base, for a start.
Old 11th September 2013, 05:27 PM   #27
Yes I have seen on some tube site that 6J1 is like 6AK5,as well as 5654, not sure about the others. But will post when I get some 5664w's for results.
Old 16th September 2013, 11:04 AM   #28
danzz is offline danzz  Spain
I bought one of those little bear P5 preamps, please keep informing about other tubes that can match.
Old 23rd November 2015, 08:37 AM   #29
Bidevind is offline Bidevind  Norway
Hi !
I just bought this chinese build Nobsound Single-ended Class A Hi-fi Tube Headphone Amplifier. Ebay-link
It uses the Chinese (not Russian) tubes 6N5P and 6N11.
Does anyone know some ekvivalent and better tubes to replace them with?
Apriciate answers
Old 23rd November 2015, 10:08 AM   #30
jazbo8's Avatar
6N5P ~ 6AS7, 6080
6N11 ~ 6DJ8
6N1 Chinese tube and othersHide this!Advertise here!
Chinese Tube Amps? samsagaz Tubes / Valves 9 30th April 2008 07:52 AM
Chinese Tube Amp? bsgd Tubes / Valves 65 5th March 2008 07:44 PM
chinese tube amp squirtacious Tubes / Valves 36 10th November 2007 05:06 AM
WTT Amp6 Int. Amp for cheap chinese tube Int. Amp mrdon Swap Meet 2 28th July 2006 12:03 PM
Chinese Tube Amp & DIY .. Pro & Con zxx123 Tubes / Valves 6 18th January 2005 10:54 AM
Copyright ©1999-2017 diyAudio
