diyAudio Sponsor
Old 19th October 2006, 04:23 PM   #1
Default ferrite beads v. grid resistor
I'm messing with a Carvin guitar amp and rather than a grid resistor such as a 68K at the input screen to V1 as on Fenders and others, they use a ferrite bead. I might swap it out just to see. Any thoughts on the pro's/cons of using a ferrite bead rather than a typical resistor here?
Old 19th October 2006, 04:53 PM   #2
cerrem is offline cerrem  United States
Basically you have a 1 turn inductor when adding a bead...
Based on the permeability of the ferite..ect.ect... This inductance is tiny and makes a -40dB/Decade filter with the input capacitance of the vacuum tube... SO we have Double Pole low pass... The problem with the bead is the L is small and the filtering is effective for RF signals..from rectification in the valve...
Chris
Old 19th October 2006, 05:03 PM   #3
rdf is offline rdf  Canada
rdf's Avatar
I've done a number of Spice simulations on that scenario and was never able to make it work to my satisfaction. Any low-resistance inductance ahead of typical grid capacitances resulted in RF frequency peaking. The peaking could be tamed by adding a resistor in series with the inductor but acceptable results only came with values of R so large as to swap the contribution of L. By that point removing the inductor had little or no effect.
Those simulations didn't account for the inductance and capacitance of interconnects and should be revisited.
Old 19th October 2006, 05:34 PM   #4
Tom Bavis's Avatar
These ferrites are lossy, and should be modeled as an inductor in parallel with a 50 Ohm resistor. Especially good for supressing VHF oscilaltions, but I don't think they'd help with say, AM broadcast interference...
Old 19th October 2006, 06:10 PM   #5
Thanks. I'm going to try some standard value resistors in place of the bead and see what happens.
Old 19th October 2006, 07:19 PM   #6
rdf's Avatar
Hi Tom, the sims were to investigate wrapping a coil around a resistor in the hope of gaining the benefit of grid-stopping at RF while presenting an effective short between input and grid at audio frequencies. The model was a resistor in parallel with an inductor. The only way I found to tame the resultant RF peaking was adding resistance in series with the coil. It typically took so much series restance to flatten the curve that removing the RL element no longer made a difference. It's possible I didn't grind at it long enough though.
Old 19th October 2006, 08:22 PM   #7
Just a reminder to make sure to model the source impedance properly that is the preceeding stage.. SInce this will make a difference..
Chris
Old 20th October 2006, 10:34 AM   #8
coresta is offline coresta  France
coresta's Avatar
Hi , on old tubed Tektro scopes , especially 581 and 585 (85MHz bandwidth!) all the 6DJ8 distributed vert amps are simultaneously neutrodyned, ferrited and grid-resistored : The only way to get stable DC - 100MHz gain . If i remember, the symetric structure of the inputs and outputs needs even some twin lead ferrite cores too.
Old 21st October 2006, 04:21 PM   #9
richwalters's Avatar
This was the old amateur radio method of reducing volume control clicks to valve inputs. As a G8xxx er in my earlier days I always assumed that any inductance even though it suppressed also acted as an aerial. One can solve a problem as well as creating another. On tube amps I prefer using old carbon resistors or true unspiralled film resistors directly on tube inputs. Another way is to wrap a component in copper foil and ground it where it is with the foil.
richj
which ferrite beads for mos legs? richwalters Power Supplies 4 28th June 2011 08:48 PM
Ferrite beads ON chips Dr.H Digital Source 11 17th March 2005 01:24 PM
ferrite beads till Digital Source 59 17th September 2004 12:28 PM
non intrusive ferrite beads jives11 Digital Source 2 29th April 2004 10:37 AM
Ferrite Beads Narcisse91 Parts 13 3rd January 2003 12:26 PM
Page generated in 0.10946 seconds (73.63% PHP - 26.37% MySQL) with 10 queries
