| diyAudio Sponsor | ||
#1 | |
I had asked for some more detailed specs on this transformer a while back, and Larry Weston sent me this today...
-Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#2 |
With that inductance and leakage capacitance, I'd use them as no higher than 4.5K/4.5K impedance, if you want HiFi performance.
But, I've underestimated Edcor's before... they have yet to not surprise me in the performance-for-price department. Hey Tubelab, whaddya know of these ones? |
#3 | |
Hey Geek,
I'm thinking about using them for a phase-splitter, maybe driving it with a 6S45PE, or some paralled 6922's. -Casey
#4 |
Hi Valveitude,
They should do the trick nicely. If it's a true bifilar wind, the capacitance for the most part cancel itself out in a balanced circuit. |
#5 | |
Show us the result then.
Regards Åke |
#6 | |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#7 |
36H should tell you enough to proceed conservatively.... Most PP
transformers have Lpri around 300 H. Case in point being the Lundahl 1660/PP which is designed for PP 6SN7 (at worst) and 20-30kHz (at best). Let empiricism rule... I have... Keep the source impedance low and keep DC off the primaries and they work well. Dont forget, the work really nicely as input transformers and are an inexpensive way to do a phase splitter. The circuit to try is this: XSM600/10K -> 6SN7 differential pair -> KT66/6V6/whatnot -> 6.6K/8 Drop a cheap CCS on the differential pair.... Drive the XSM600 input from a decent PC sound card with 600 ohm XLR out. Golden. Immaculate. -- Jim |
#8 |
The capacitance is not shunt, but between primary and secondary. This is typical of bifilar wound transformers. You can think of it as a 'hidden' coupling cap. Provided it's connected properly (you don't try to use it to invert phase) the capacitive coupling actually improves hf response where the inductive couple becomes less effective.
-- Dave |
#9 |
41 nF for 10K is toooo much. It improves "performance" of asymmetrical leakage.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
| Edcor specs? | Fuling | Tubes / Valves | 0 | 11th January 2009 09:06 PM |
| Edcor XSM10K/15K like intestage in tube SE ? | Angelm | Tubes / Valves | 1 | 28th May 2008 11:32 PM |
| Edcor outputs? | kegger | Tubes / Valves | 4 | 3rd February 2007 04:35 PM |
| Edcor OPT's | bloozestringer | Tubes / Valves | 23 | 3rd January 2007 05:27 AM |
| Edcor amplifier --> 6l6 PP | guitvinny | Tubes / Valves | 2 | 13th May 2006 03:18 AM |
| Page generated in 0.09791 seconds (78.80% PHP - 21.20% MySQL) with 10 queries |
