diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   This is incredible!--An audio epiphany!! (http://www.diyaudio.com/forums/tubes-valves/8822-incredible-audio-epiphany.html)
RADIOLEE 19th December 2002 03:01 AM
So here's my system-
All signals(turntable, CD, mini-disc, DVD) are feeding into a McIntosh MX-110 tuner preamp.
The output is now fed into a passive line level crossover I just put together for about three bucks after finding this website-
http://139.142.118.15/sites/diy/tech...ssiveHLxo.html
I used four 10k ohm resistors and four .050 picofarad capacitors I had laying around.
I figure it's crossing over about 750.
I fed the lows into a - get this- Silvertone single ended 6BQ5 amplifier out of a console I bought at a junk store for 25 bucks.
I fed the high end into two Electronics Tonalities S.E.X single ended monoblocks I bought on eBay.
The lows feed the 421A Altec woofers and the highs to the 808-8A Altec horns in the A-7's.
I'm not going to gush, BUT , I've been listening to Audio for a long time and this is a whole new ball game.
Lee
peterr 19th December 2002 07:36 AM
it may be me, but the link doesn't work
rendisha 19th December 2002 07:39 AM
Remove dot at the end of the link.
dhaen 19th December 2002 09:02 AM
Making friends with the local bat population?:D
halojoy 19th December 2002 09:06 AM
bats need some friends too.
You mean that the frequency can not be heard by human ears???
RADIOLEE 19th December 2002 09:17 AM
Guess you all can tell, I'm no tech...
.000000050 farads - would that be microfararads???
Doesn't really matter to me, the sound is the same!
Am I the only one who thinks that it sounds like someone is mocking you when he cuts and pastes part of a topic when replying to it.............
Peace
Lee
dhaen 19th December 2002 09:32 AM
Hi Lee,
I knew you meant microfarads...
No offence intended. Just saw you'd made a slip;)
Some of us have nothing better to do:apathic:
phase_accurate 19th December 2002 09:36 AM
Hi Lee
There's only one thing that bugs me: I don't know the particular type of SE amplifier you use but I guess it is one with only very low output power. I nevertheless wonder if this 6dB/octave crossover is really sufficient for a horn driver ?
Charles
Brett 19th December 2002 11:09 AM
Why wouldn't it be?
phase_accurate 19th December 2002 12:13 PM
... because most horn-driver datasheets recommend 2nd oder or higher (i.e. I didn't even bother to listen to the differences though I have used quite some horn-drivers already).
Charles
Copyright 1999-2017 diyAudio
