This is incredible!--An audio epiphany!!
Old 19th December 2002, 06:51 PM   #31
Brett is offline Brett
Brett's Avatar
Originally posted by dhaen
Good for the source, but the destination wiring must be short.
Thanks John, good point. I always put the networks at the amp inputs or between amp stages, and I should have added it for clarity.
Which ribbons? All the ones I've ever heard sounded awful (to my ears), although the new ESg range looks interesting.
Cheers
Old 19th December 2002, 07:04 PM   #32
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Bi-amping can yield huge improvements, and with SE amps removing the reactive XO components makes the amps a lot happier.
The PLLXO parts can be put between stages inside your amps for even greater simplification.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th December 2002, 07:09 PM   #33
frugal-phile(tm)
planet10's Avatar
The only ones i've heard for any extended time were the Decca London ribbons, and they were very fine -- and horn loaded so they would have a better chance of integrating into your systen Brett.
dave
Old 19th December 2002, 07:12 PM   #34
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default DECCA LONDON
Hi Dave,
I'm not sure about the effeciency of the ribbons on their own but
didn't the Decca London have an overal effieciency of ~88dB?
Frank
Old 20th December 2002, 05:02 PM   #35
RADIOLEE is offline RADIOLEE
Brett-
Thanks for the tip on the internal capacitor.
Having bought these on eBag, I didn't get a schematic.
Dan at Electronic Tonalities is a great guy, and I have always found him very accessible and helpful.
Do you have any experience with his 2A3 amps? I am considering buying a couple so I can have a whopping 5 watts to drive the altecs.
Anybody want to buy a Hafler 500????
Ho Ho Ho
Lee
Old 20th December 2002, 05:25 PM   #36
Brett's Avatar
Nope. I'm not a big fan of SETs because they all sound muddy to me (well all I've ever heard). When my system is complete, I'd like to try some parafeed designs as it only means the purchase of some chokes.
Also, before you decide on a low watt amp, get a RatShack SPL meter and check how loud you like to listen, and back calculate power requirements, with headroom, from this. You might find 5W isn't enough to not sound compressed on peaks. A SE 2A3 will have a fair bit of (obvious) distortion at 5W!
I have horns and I use more than this. FTR, my <i>average</i> listening level is about 85dB or so, with peaks obviously extending well above that.
Old 22nd December 2002, 12:07 AM   #37
bob4 is offline bob4  Germany
bob4's Avatar
Location: (Black Forest, Germany) currently southern Finland
Hi folks,
I wanted to ask if the passive line level crossover would be ok for PA?
Old 22nd December 2002, 12:10 AM   #38
fdegrove's Avatar
Default JUST DON'T TELL ANYONE.
Hi Bob,
Pssssst...
Industry's best kept secret...
Bob..Why shouldn't it?
Ciao,
Frank
Old 22nd December 2002, 12:55 AM   #39
frugal-phile(tm)
planet10's Avatar
With proper driver choice it would probably work fine, but at a sacrifice to ultimate loudness capability.
dave
Old 22nd December 2002, 02:59 AM   #40
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
I'd like to put a passive line-level xover between two tube buffers, would this be a good idea, or should I just build a traditional active xover? I really don't need a high order slope and would prefer a 1st or 2nd order slope anyways. Are there any advantages to a "normal" active xover compared to the one I want to make? Or is there any point to putting it between two tube buffers, maybe I should just keep it between my preamp and amp? I'd rather stay away from feedback, and with a pllxo I can acomplish that and keep the parts count low and relatively cheap (so I can make a switch to select frequency and order).
This is incredible!--An audio epiphany!!Hide this!Advertise here!
Incredible story. GK The Lounge 8 29th August 2008 03:25 AM
Any details about Epiphany E-Cube? needtubes Subwoofers 2 13th August 2005 07:34 PM
Epiphany drivers? Gaucho Multi-Way 4 14th January 2005 02:04 PM
The Epiphany organ - 74 channels and 15000 Watts! ashwin Everything Else 1 4th December 2003 07:20 AM
Incredible Howard Multi-Way 7 17th August 2003 10:04 AM
