| diyAudio Sponsor | ||
Sorry for that maybe kinna "trivial" question, but there's allways good ideas underneath I think.
Here's mine, a usefull test bed/setup i like having is: > An AC mVmeter that I can connect everywere (from 1mV/-60dBm to 300V/+50dBm) which, through its internal amplifier is feeding the oscilloscope (also connected to the source, this is the bottom scope) > An AF wobulator (is this the right translation of the french wobulateur ??? it's home made with a returm amplifier) connected X/Y to the upper scope (which also serve as a component tester) > Maybe I can also mention, the X/Y on power grids trick for phase inverters testing. this setup provides me a great gain of time compared to before. any tricks to share ? (don't trust too much the picture, this place is most of the time a mess )
Plus je pédale moins vite, moins j'avance plus vite ! |
#2 |
Dell Inspiron 9300 notebook with Tascam US-122 sound adapter, Hitachi V-555 oscilloscope, Wavetek 154 signal generator, HP 4000 vacuum tube voltmeter, Marconi TR 2091B noise generator, couple of handheld voltmeters, Atten F1000-C frequency counter. And lot of transformers, tubes, transistors, capacitors, etc... Soldering tools 30W, 60W, 120W.
Your mess looks like a good setup to work, I'll not post mine, it is the real mess.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
are you operating at home too ?
#4 | |
| Cult movies - what is your favorite - what is your favorite part | Ken L | The Lounge | 243 | 15th February 2010 04:09 AM |
| Need a tool! | Tenson | Multi-Way | 12 | 19th March 2007 08:36 PM |
| TL design tool? | mazeroth | Multi-Way | 3 | 22nd May 2006 08:03 AM |
| Demagnetising Tool/Tool Demagnetiser | mrfeedback | Everything Else | 30 | 4th October 2002 11:53 PM |
| Page generated in 0.07373 seconds (71.97% PHP - 28.03% MySQL) with 11 queries |
