My new project, 2 x KT88 60W amp - Page 3 - diyAudio
Old 17th November 2006, 02:09 PM   #21
Yeah .. cool stuff.. I'm motivated to set up an LCD screen above my bed so I can read it all....
Check out this related thread
Question about DIY EL34PP amp
Old 17th November 2006, 02:41 PM   #22
well it seems that we are building similar projects
I will make some modifications to the schematic of that PDF. I wont use a pentode for the first stage, will be something like this:
first stage: 12AX7 diff-amp with a solid-state current source
driver: 12AU7
output: 2xKT88
Old 20th November 2006, 04:28 PM   #23
Power supply:
the 500v supply:
8x220uF 400V caps for the power supply
2x 0.47uF 630V
4xBY228 fast diodes (1.5KV / 2A)
And the bias power supply (bridge diodes + 470uF)
Phantom load for measurement (6 ohm)
Old 26th January 2007, 10:45 PM   #24
Long time ago since my last post.
The project is going well. I have to make some adjustments (Feedback, etc)
some pictures:
In this next picture, look just below the PSU transformer. It's the 10H 250ma choke good support for the PSU trans.
What do you think? isn't beautifull??
Old 26th January 2007, 10:48 PM   #25
Just out of curiosity....
I thought that it was always 'best' to place the PT 90 degrees from the OPTs to prevent coupling ? Furthermore, I thought it was best to mount the power choke out of phase as well...Perhaps I am mistaken ?
Steve
Old 26th January 2007, 10:54 PM   #26
I didn't know about that. I hope you're wrong
By the way, it only has a little hum that I still have to fix.
Old 26th January 2007, 11:41 PM   #27
kevinkr's Avatar
No, actually he is right, but in this instance you may get away with it. (or not) In your next project though you definitely want to mount the output transformers at right angles to the power transformer.
How about some pictures of the underside of your amplifier? May help some of us identify other potential sources of hum in your amplifier.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th January 2007, 12:18 AM   #28
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It will be simplier to rotate output transformers, it seems to me the power tranny rotated will not fit...
The Devil is not so terrible as his math model is!
Old 27th January 2007, 02:58 AM   #29
rotating the two output transformers will be boring and annoying but can be made simply. In fact, i think i could use the same holes.
Here is a pic of the connection side.
It's not finished. I'm making a little bit of order. When I used the amp for the first time it was a mess , really a mess of cables & stuff.
Old 27th January 2007, 09:39 AM   #30
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Default twist
all heaterwires should be twisted, perhaps better not to hop from tube to tube but all heaterconnections to central startingpoint.
make sure there is only 1 earth point connected to the chassis.
shielded wire from inputplug to first tube.
use gridstoppers everywhere
2A3 or KT88 ? 6J7 Tubes / Valves 8 19th April 2009 11:52 AM
My KT88 SE project JesseG Tubes / Valves 8 20th April 2008 04:26 AM
Project choice for KT88 JDeV Tubes / Valves 6 16th August 2005 07:27 PM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
Would it be possible? OTL/OCL KT88? Layberinthius Tubes / Valves 4 24th January 2004 11:31 PM
Copyright 1999-2017 diyAudio
