diyAudio Sponsor
Old 10th October 2006, 03:29 AM   #1
dsavitsk's Avatar
Default Benefits of Potted Output Transformers
I have some James transformers that have cases around them, which I guess means they are potted. Does this mean I can not worry about their proximity to chokes and power transformers, or perhaps worry a little less, or is this not the benefit of potting them.
Old 10th October 2006, 03:34 AM   #2
jarthel is offline jarthel  Australia
Default Re: Benefits of Potted Output Transformers
runs cooler I believe
and looks sexy that than using "end bells" (typo?)
Old 10th October 2006, 03:48 AM   #3
SY's Avatar
Neither. The potting has no/very little effect on magnetic fields. And it actually can decrease cooling. It's done for better environmental isolation (particularly moisture), lower vibration, and because it looks and feels cool. Sexy indeed!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 10th October 2006, 03:52 AM   #4
HollowState's Avatar
Actually I believe the most important benefit of potting is preventing moisture from getting in the windings as well as physically sealing it against vibration. Yup, it also looks nice too. Unless there is a mu-metal shield inside, there's often no better shielding then a regular end bell. And call me cynical if you want, but it also helps deter getting at it to reverse engineer it.
Victor
Old 10th October 2006, 04:10 AM   #5
dsavitsk's Avatar
Is there a good way to determine optimal direction vis a vis the power transformer/chokes. or is it a matter of bread boarding one way, and then turning 90 degrees to see which is better?
Old 10th October 2006, 04:25 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi dsavitsk,
That's about it. Low tech, but it works.
-Chris
Old 10th October 2006, 08:58 AM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
You can be a bit theoretical. Think of the mains transformer as having the coil that is the primary of a transformer and the output transformer as having the coil that is the secondary of that same transformer. You now want to make the coupling of the notional transformer as poor as possible. Orient the coils at 90 degrees to one another and get as much distance between them as possible. Fine tweaking when you've made it may help.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th October 2006, 09:11 AM   #8
Potting has its pro and cons
When you pot it looks nice
it prevents high tension build up and prevent corona discharge
No moisture can build up within the coils.
Helps to slighlty reduced vibrations as the epoxy acts as a dampener
Cons
The trans runs hotter as there is no air flow
For audio trans the potting materials will act as a dielectric
most potting material like james is epoxy which is bad for sound. The good sounding potting material which wax on the other hand melts at 60-90 C depending on wax types
Old 10th October 2006, 09:25 AM   #9
EUVL is offline EUVL  Europe
According to my very limited understanding, all potting compounds, polyurethane or epoxy based, shrink when they set (ca. 3 vol %). The shrinkage inevitably put the core/winding under stress (deoends on construction, elastic modulus, .... ). Stress in laminated cores reduce their saturation level, by as much as 30% if I remember correctly. Epoxy is worst than varnish in that respect.
But of course you can design for this, by using a larger core.
Patrick
Old 10th October 2006, 11:07 AM   #10
SY's Avatar
True, but how do you know the coil orientation when it's all buried in a chunk of polymer and metal?
Having built my first amps using James iron, I can attest that there's nothing whatever wrong with the way they sound. Superb transformers.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Potted transformers semitone Tubes / Valves 22 13th January 2008 12:00 AM
potted transformers resident Tubes / Valves 24 13th November 2004 05:55 PM
benefits of dual mono transformers in Aleph? glyphin Pass Labs 1 10th September 2002 10:01 PM
Page generated in 0.12665 seconds (81.63% PHP - 18.37% MySQL) with 11 queries
