| diyAudio Sponsor | ||
Ive build my amplifier, do I have to isolate the output tranny ? because when I dont do it I got a short on my power sup... and when I isolate them from the chassi it work perfecly...
thank |
#2 |
Primary is shorted. I would not use such a transformer.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
After reading your question, my first thought was that you may have a shorted transformer. Specifically a short of the primary to the core or possibly to the secondary, assuming the secondary common is grounded.
On second reading you mention isolating "them" meaning two (2). Is this a stereo amp, and do both transformers cause a short? If so, perhaps you have made a wiring error. What are we dealing with here? Push-Pull or singel ended? What transformers are you using and where did they come from? Output transformers should never need isolation from the chassis or ground. Victor |
#4 |
Only one made this, its a 2 channel push pull, those tranny came from edcore`s custom shop...hopefully I`ve buy 3 tranny instead of only 2... maybe should I try the other one next week
#5 |
A few simple measurements with a DMM should tell you if you have a short and where it is. Measure primary to core, primary to secondary, and secondary to core. You should see an open circuit in all cases.
It might be possible that a shorted primary will not show up without high voltage on the core. That can be measured (very carefully) by checking the voltage from core to ground with the transformer isloated from the chassis and power on. Before you do that, though, you might remove the bells and check that you don't have an obviously pinched wire. Sheldon |
| Quick Amp6-Basic Question | revans | Class D | 2 | 2nd August 2008 04:12 AM |
| simple and quick question | rinx | Multi-Way | 6 | 20th March 2008 03:13 PM |
| A few simple questions about basic TL's. | O_ROD | Full Range | 21 | 8th February 2007 11:08 PM |
| The Need For a New Quick Simple Project... | Rino odorico | Digital Source | 4 | 2nd September 2003 07:22 PM |
| quick and simple question | McBain | Solid State | 3 | 16th August 2002 05:38 PM |
| Page generated in 0.08209 seconds (74.25% PHP - 25.75% MySQL) with 10 queries |
