John Broskie's enhanced T8 - Page 2 - diyAudio
Old 8th October 2006, 04:06 AM   #11
Oh, for the love of... Here:
http://img204.imageshack.us/img204/8...circuitkt2.gif
For what it's worth, I don't think the granting of a patent guarantees the excellence of a design. I'm basically a cheap guy by nature. EL509s are getting scarce and pricey. If I could modify the circuit for a different tube that I have on hand, I'd do it. I've got 6KV6s I'd like to try. Maybe someone else has other tubes. It's the knowledge I'm after. I think in this case it might just be the grid and cathode resistors values. I just don't know how to translate tube characteristics into circuit values.
Knowing the history of BR's responses to tube substitution questons in his products on the Transcendent message board, I thought I'd have more luck here.
Old 8th October 2006, 05:28 AM   #12
Thought the Russians or the Chinese still made EL509's but failing that there should be a plentiful and cheap supply of PL509's.
Old 8th October 2006, 06:26 AM   #13
5u4 is offline 5u4  United States
5u4's Avatar
I would think the main concern would be the bias voltage.
The purpose of the 100k grid stoppers are to isolate each tube in case of a grid short.
Don't know of any reason to change the value of the 30K grid to bias resistors for a 6KV6 or due to the different driver...... or the 170V...... or the screen resistors. Perhaps one of the EE's will help out here.
The 2 ohm cathode resistors are to help prevent a tube from hogging current.
Perhaps you already know all this. If you do I appologize, just trying to help.
Old 8th October 2006, 07:13 PM   #14
Thanks 5U4,
No tidbit of information is wasted on me since I'm basically just a schematic jockey.
John Broskie Aikido boards Burnedfingers Tubes / Valves 1 12th October 2010 09:57 PM
John Broskie's headphone design using pentodes Brit01 Headphone Systems 14 15th July 2009 03:28 AM
Broskie OTL woody Tubes / Valves 1 18th October 2007 06:18 AM
Where is John Broskie ? reinhard Tubes / Valves 7 8th October 2002 02:27 PM
Copyright 1999-2017 diyAudio
