Adding Treb and Bass adjustment?!
Old 18th December 2002, 09:37 PM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default WHY WORRY?
I think the headwize ckt is a little extreme w/ 6 tubes for 2 channels.
Those tubes are there for a reason.
Every stage is elegantly buffered from the other.
I like it.
Joel,
What page is that circuit on the the Bible?
Frank
Old 19th December 2002, 02:15 PM   #12
Joel is offline Joel  United States
Joel's Avatar
Default Re: WHY WORRY?
Originally posted by fdegrove
Joel,
What page is that circuit on in the Bible?
I can look it up tonight Frank, but it's near the end of the tone controls section.
Again, I have to say that I think the passive controls are not the way to go here, unless you're building a guitar amp. Just too much stuff coupling the stages. And they have a very sharp slope. Look at the response curves for the circuits also - the actives have nice gentle curves. Ooo lal la.
Old 19th December 2002, 02:20 PM   #13
fdegrove's Avatar
Default TONE CONTROLS
Hi Joel,
Thanks.
Have you looked at the circuit at the Headwize site?
If so,any thoughts?
Frank
Old 19th December 2002, 02:24 PM   #14
Joel's Avatar
Do you have the link?
Old 19th December 2002, 02:28 PM   #15
fdegrove's Avatar
Default I AM THE LINK.
Hi Joel,
Yes.
Do you?
Here it is:HEADWIZE
Frank
Old 19th December 2002, 02:49 PM   #16
Joel's Avatar
Frank, I don't understand the function of the bottom three 12AX7's. Can you explain it?
Old 19th December 2002, 03:16 PM   #17
fdegrove's Avatar
Default CAN DO
Joel,
If you look at the various input caps you'll see that those bottom CFs define the three center frquencies.
Frank
Old 19th December 2002, 03:41 PM   #18
cadman is offline cadman
cadman's Avatar
You make a good point about the headwize circuit Frank. I had dismissed it because of its 150/-150 supply reqs but I can steal that from the preamp supply. Could you tell me, what's the function of the 12AT7? Gain?
This may be the route to go, I have a source for motorized 10k pots and of course I've never needed an excuse to add more tubes
Old 19th December 2002, 03:42 PM   #19
Joel's Avatar
Default Re: CAN DO
Yes, I see the differing values, but I don't get how the single connection (via the grid) works with the rest of the circuit.
Old 19th December 2002, 03:51 PM   #20
fdegrove's Avatar
Default TONS OF CONTROL
I doubt it.
You would also be better of with a separate box holding your circuit and PSU IMO.
Also you'll need heater supply,don't forget that either.
No,cathode followers are essentially buffers,the 12AT7 was probably chosen for its' lower output Z as opposed to the 12AX7.
Gain is defined by the input tube.
Frank
Adding Treb and Bass adjustment?!Hide this!Advertise here!
BOZ bias adjustment help rtate Pass Labs 16 11th July 2008 07:04 PM
Will adding a 10H/125mA choke hurt bass performance andy2 Tubes / Valves 10 22nd February 2006 12:55 AM
Bass and treble adjustment in gainclone pikkujöpö Chip Amps 9 4th November 2005 05:23 PM
Adjustment of CDM 4/19 ,any help please! zygibajt Digital Source 0 20th November 2004 10:18 AM
Some questions about C4S CCS adjustment. G Tubes / Valves 11 5th May 2004 09:03 AM
